Startech pm1115p2
31 May 2024 01:54 #301914 by Lostcnc
Startech pm1115p2 was created by Lostcnc
Hi, I'm new to this. Has anyone used startech ethernet to parallel interface (part# pm1115p2) www.google.com/url?sa=t&source=web&rct=j...FOPaCpFRZtNDbqpTU7FG
is it possible to use this to plug into a cheap chinese bob?
31 May 2024 03:38 #301919 by tommylight
Replied by tommylight on topic Startech pm1115p2
No it is not possible to connect to a BOB as it has the Centronics 36 pin port, not the DB25 one, and making an adapter (probably no way to find it) would probably require some junk yard scavenging to find a female Centronics port.
All that is probably in vein as it might not work with LinuxCNC at all.
And now the hard answer:
Go buy a Mesa 7i92T, it is the same price, has two ports with 34 IO all can be inputs or outputs, and can do much, much faster step rates and read fast encoders.
31 May 2024 04:04 #301920 by Lostcnc
Replied by Lostcnc on topic Startech pm1115p2
Thanks for the help. I was looking at the 7i92t. I seen that parallel adapter and just thought I would ask.
31 May 2024 04:38 #301922 by tommylight
You are welcomed, always.
Just to be clear, i have nothing to do with Mesa, i did my first retrofit with their boards a long time ago, and many more since then as i absolutely must have reliability, and those do. Also, any price you see for Mesa stuff, i have to pay at least twice that to get it here, and i pay it gladly.
For the price of the adapter you linked with big chances it will not work, you can also get a used PC with parallel port that works perfectly well with LinuxCNC, the port works, PC might still have issues with latency, but the big Dell Optiplex 980 have worked fine for me.
But if you can stretch a bit, get the 7i96S, makes wiring much easier.
  • Platinum Member
  • Platinum Member
31 May 2024 04:50 #301923 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Startech pm1115p2
That's an old school print server, not an ethernet to parallel adapter.
31 May 2024 05:50 #301926 by tommylight
Yes it is, 8 data pins, 4 control pins and 5 status pins, if i am not mistaken.
  • Platinum Member
  • Platinum Member
31 May 2024 07:12 #301928 by Cant do this anymore bye all
That is correct, I had an old 2 port HP one in the late 90's, couldn't print to the "win printers' of the time. Laser jets had no issues with.
Time to create page: 0.922 seconds
