- Hardware & Machines
- Computers and Hardware
- Logitech F310 shows in lsusb but HAL config does not show it - still strange
- garthnoakes
- Thank you received: 9
21 Aug 2024 15:33 #308305
by garthnoakes
Logitech F310 shows in lsusb but HAL config does not show it - most strange was created by garthnoakes
I have two identical PCs, same version (latest 2.9.3) of LinuxCNC, same F310. One worked immediately - on the other, the F310 shows from lsusb (the output is identical on the first PC). But HAL config does not show the input pins on the second one.
I didn't do anything different in the installs.
Both are set to X mode
- garthnoakes
22 Aug 2024 01:52 #308361
by garthnoakes
Replied by garthnoakes on topic Logitech F310 shows in lsusb but HAL config does not show it - most strange
The gamepad also works fine using jstest. So Linux has no problem with it - just something wrong with linuxcnc seeing it
- garthnoakes
22 Aug 2024 16:19 #308409
by garthnoakes
Replied by garthnoakes on topic Logitech F310 shows in lsusb but HAL config does not show it - still strange
I found that in the hal file that uses loadusr -W hal_input -KRAL <identifier>, I had overwritten this with the wrong value when reinstalling LinuxCNC and copying the hal files from backup
I changed the identifier to F310.
When I run halrun from the command line and input the above (loadusr -W hal_input -KRAL F310) and <show pin>, I now see the input pins correctly. So hal is now working
But when I run LinuxCNC itself, I still don't see the pins (using HAL config or monitor).
Time to create page: 0.076 seconds
