IRQ Affinity setup
- rajsekhar
- Thank you received: 12
13 Oct 2024 07:55 - 13 Oct 2024 07:58 #311964
by rajsekhar
IRQ Affinity setup was created by rajsekhar
Please refer the below message
Last edit: 13 Oct 2024 07:58 by rajsekhar.
- rajsekhar
13 Oct 2024 07:56 #311965
by rajsekhar
Replied by rajsekhar on topic IRQ Affinity setup
RQ Affinity setup
was created by
rajsekhar
Hi..I am doing a machine using MESA boards.
Over last few weeks, I have overcome the computer latency issue, Many thanks to this forum. Now, max jitter comes within 40,000ns for both base thread and servo thread.
But network latency continues unless I use IRQ affinity.
I had run tests and result as follows:
with enp4s0(my network hardware) interrupt in CPU0:
raycnc1@debian:~/Desktop$ sudo chrt 99 ping -i .001 -q 10.10.10.10
[sudo] password for raycnc1:
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
966462 packets transmitted, 966461 received, 0.00010347% packet loss, time 967436ms
rtt min/avg/max/mdev = 0.096/0.100/7.930/0.009 ms
^Craycnc1@debian:~/Desktop$
And with interrupts in CPU1 (i.e last CPU)
7762711 packets transmitted, 7762710 received, 1.28821e-05% packet loss, time 7770480ms
rtt min/avg/max/mdev = 0.048/0.095/0.267/0.027 ms
Note 1) In CPU0 result, max time is 8ms almost compared to 0.3ms in other case. So IRQ affinity setting is essential.
Note 2) The affinity setup is done for test using a script from PCW, but that require manual command run after every boot, not run automatically.
So, I have failed to do the IRQ setup.
I did follow the Mozmck post.
forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity
The network interface file is attached. I assume it is not as per the requirement. I have attached IPV4 setup page photo for ip setting values.
Need help.
Need help.
- Thank you received: 5337
13 Oct 2024 11:50 - 13 Oct 2024 11:53 #311989
Replied by PCW on topic IRQ Affinity setup
Mozmck's script requires your interfaces file to setup the interface and that the host IP address
in parts of his script are changed to match that IP address in the interfaces file.
Alternatively, maybe adding my little script to the Linuxcnc startup script would be a simple solution
(the command "linuxcnc" is a script)
Last edit: 13 Oct 2024 11:53 by PCW.
The following user(s) said Thank You: rajsekhar
- rajsekhar
13 Oct 2024 20:35 #312020
by rajsekhar
How to add to kinuxcnc startup script? Please guide, it is new thing for me.
13 Oct 2024 22:09 #312026
Well it ends up being a bit awkward because it needs root privleges
probably the easiest is to add it to the startup using systemd
- rajsekhar
14 Oct 2024 07:33 #312054
by rajsekhar
Well, I followed some youtube videos..made two files attached.
irq32affinitty.sh put in /usr/local/sbin
irq32affinitty.service in /etc/systemd/system
My enp4s0 irq number is 32. It does not change normally, hardware change might do so, I have not checked that.
My target is : echo 2 > /proc/irq/32/smp_affinity
the irq32affinity.service works fine when started with systemctl command i.e after login.
But it fails to execute during booting.
I think service shall be started after login, but how to set that.
Request for suggestion.
14 Oct 2024 08:30 #312058
Here's a fair description of whats needed:
www.howtogeek.com/687970/how-to-run-a-li...tartup-with-systemd/
- royka
- Thank you received: 135
14 Oct 2024 09:46 #312064
by royka
Replied by royka on topic IRQ Affinity setup
Otherwise in /etc/rc.local above "exit 0": sleep 10 && echo .....
Or "sudo crontab -e": @reboot sleep 10 && echo ......
The sleep is necessary with the orange pi at least.
- Thank you received: 7505
14 Oct 2024 09:51 #312066
Replied by tommylight on topic IRQ Affinity setup
rc.local would work, but not sure it is usable still on Debian, i know Mint stopped using it a while back, but it can still be made to work with a bit of fiddling.
The following user(s) said Thank You: royka
- rajsekhar
15 Oct 2024 02:07 #312128
by rajsekhar
rc.local is absent.
However, I somehow managed it.
In case someone need to do the same, steps are given below.
Note2: It is done on LCNC2.9.3/ Debian
Note3: Any change in last CPU number/ network hardware Interrupt number will require reconfiguration of .sh file.
Note4: No need to enable irq32affinity.service by 'systemctl enable' command.
- Find out Interrupt number for network device by 'watch -n1 -d cat /proc/interrupts'. in my case it is 32.
- Check your last CPU number. In my case it is CPU1, so 'echo 2' to be set. This link may be helpful: bitsum.com/tools/cpu-affinity-calculator/
- create two file as attached in my post above dated 14 Oct 2024 12.33. Put them to respective directory as mentioned. chmod a+x for both files.
- go to 'Setting', then 'Session and Startup', then under 'Application Autostart' tab, click 'Add'
- under command, type "sudo systemctl start irq32affinity.service", Trigger 'on login', save.
- go to '/etc' directory, open terminal, type 'sudo geany sudoers'
- add '<user name> ALL=(ALL) NOPASSWD: /usr/bin/systemctl' at the bottom. putting in middle may not work.
- save and close geany.
- restart and check IRQ affinity.
The following user(s) said Thank You: tommylight, Muftijaja
Time to create page: 0.153 seconds
