rp1lib - user space driver for the RP1 chip
  • scotta
  • Platinum Member
  • Platinum Member
19 Oct 2024 18:59 #312637 by scotta
People may have been wondering why I have been a little quiet on the forum of late and that pull requests to Remora have been slow to be merged. Well, I've been working away on getting SPI on the Raspberry Pi 5 working so that we can support the SPI version of Remora. I'm now happy to share where things are up to.
github.com/scottalford75/rp1lib
The BCM2835 library was the inspiration, a library that gave access to all the chip peripherals. Hopefully the rp1lib can become the start of something similar.
Rather than reinventing the wheel, the library utilises the gpiochip_rp1 library for GPIO and I've adapted the kernel Designware driver for user space.
Next step is to update the Remora component, which is not too far off as I've got the RPi version detection working already.
  • Moderator
  • Moderator
19 Oct 2024 19:37 #312638 by tommylight
Replied by tommylight on topic rp1lib - user space driver for the RP1 chip
People may have been wondering why I have been a little quiet on the forum of late ...
I know i have.
-Pinned to find easily.
Thank you for everything.
P.S.
Why rp1lib? Why not rp5lib?
Just wondering, as i am not into RPI for quite a while.
  • scotta
  • Platinum Member
  • Platinum Member
19 Oct 2024 23:41 #312648 by scotta
Replied by scotta on topic rp1lib - user space driver for the RP1 chip
Getting closer. The remora-spi LinuxCNC component can now:
1. Detect the RPi 5 and initialise the RP1 SPI
2. Can come out e-stop! Comms are up when testing with an Octopus board, but getting some errors reported
Need to play with speed settings etc to see if that helps.
Getting very close now :-)
20 Oct 2024 00:23 #312649 by Aciera
Replied by Aciera on topic rp1lib - user space driver for the RP1 chip
It's what the new chip is called that controls the IO on the Rpi5
www.raspberrypi.com/news/rp1-the-silicon...ere-at-raspberry-pi/
  • Moderator
  • Moderator
20 Oct 2024 03:46 #312651 by tommylight
Cornholio is going to be very happy! :)
Time to create page: 0.326 seconds
