Remora rp2040 compile issues.
- Gluca
09 Nov 2024 19:11 #314137
by Gluca
Remora rp2040 compile issues. was created by Gluca
Hi all!
I've been trying to use wiznet w5500-evb-pico as step generator for linucnc.
I was successfull loading remora-rp2040-2.0.0.uf2, from github.com/scottalford75/Remora-RP2040-W5500
But, when trying to compile, i was less lucky:
/tmp$> cmake -DPICO_SDK_FETCH_FROM_GIT=on ./Remora-RP2040-W5500-main/
/tmp$> make
I've got some include errors like: pico_bootrom/bootrom.c:9:10: fatal error: boot/picobin.h: No such file or directory
#include "boot/picobin.h"
The same for: runtime_init.h,runtime.h
But those files are available in the sdk source.
My Q&D solution was to copy locally to complete the build.
After that, the build made a loadable uf2 image.
But the rp2040 has been crashing during my tests.
Suggestions?
Gluca.
/tmp$> make
Suggestions?
Gluca.
- cakeslob
- Thank you received: 280
13 Nov 2024 14:48 #314380
by cakeslob
Replied by cakeslob on topic Remora rp2040 compile issues.
are you compiling with release or debug? idk which one but people report trouble with one
- Gluca
13 Nov 2024 20:18 #314403
by Gluca
Replied by Gluca on topic Remora rp2040 compile issues.
I'm just compiling with this sequence:
/tmp$> make
Explain me better ...
/tmp$> make
- cakeslob
14 Nov 2024 04:53 #314419
by cakeslob
stackoverflow.com/questions/7724569/debug-vs-release-in-cmake
cmake.org/cmake/help/latest/guide/tutori...20and%20Release.html
after re-reading the question later, im not sure this will help
- Gluca
14 Nov 2024 21:16 #314487
by Gluca
Nothing to do.
After:
> cmake -DPICO_SDK_FETCH_FROM_GIT=on -DCMAKE_BUILD_TYPE=Release ./Remora-RP2040-W5500-main
> make
OR
> cmake -DPICO_SDK_FETCH_FROM_GIT=on -DCMAKE_BUILD_TYPE=Debug ./Remora-RP2040-W5500-main
> make
It always exits with "fatal error".
After:
> make
OR
> make
- Gluca
16 Nov 2024 10:16 #314590
by Gluca
Hi all!
This issue was already known:
github.com/scottalford75/Remora-RP2040-W5500/issues/10
After: git clone github.com/scottalford75/Remora-RP2040-W5500
in pico_sdk_import.cmake, change GIT_TAG masteÅ— to GIT_TAG 1.5.1 in lines 37 and 44
Than:
cd Remora-RP2040-W5500
mkdir build
cd build
export PICO_SDK_FETCH_FROM_GIT=TRUE
cmake -DPICO_BOARD=pico_w ..
cmake -DCMAKE_BUILD_TYPE=Debug . -DPICO_BOARD=pico
make clean
make
Now, the build process reaches its end with a functional firmware.
Than:
mkdir build
cd build
make clean
make
Time to create page: 0.395 seconds
