One laptop + several machines using Mesa cards.
- Boogie
- Thank you received: 9
14 Feb 2025 20:44 #321585
by Boogie
One laptop + several machines using Mesa cards. was created by Boogie
Gents,
mancave conditions: several cnc machines but will use one at the time. Plan to use lenovo T470 touch laptor with LinuxCNC on it. Each cnc machine will have Mesa on board (some ethernet model). One thing is bothering me: each machine Mesa card will have specific bit file. How about LinuxCNC on laptop? Is it possible to have several "profiles" so i can simply switch one machine off, disconnect ethernet cable, go to the next one with my laptop, plug eth in and just start machine specific profile and just use it? What if i want to use this nice black/yellow high contrast GUI
on plasma, but then regular AXIC on the router then lathe specific one.
Can it be done?
Can it be done?
The following user(s) said Thank You: behai
- Thank you received: 7488
14 Feb 2025 22:20 #321599
Replied by tommylight on topic One laptop + several machines using Mesa cards.
Yes.
- Thank you received: 5330
14 Feb 2025 22:21 #321600
Replied by PCW on topic One laptop + several machines using Mesa cards.
Just needs appropriate configuration (hal and ini) files for each machine
- Boogie
15 Feb 2025 12:49 #321629
by Boogie
Replied by Boogie on topic One laptop + several machines using Mesa cards.
Perfect. So each Mesa will have its own BIT file, specific to machine it is installed in and on the laptop side INI + HAL per machine. So it looks like GUI is invoked by INI file and each machine can have a different one. Nice. Looks like nice, interesting and long adventure:) Thank you.
15 Feb 2025 16:28 #321651
I do have several machines with multiple configs, meaning one machine has several configs, made things very easy for tube cutters as i set them as normal 3 axis machine and use a config for each diameter tube.
That way, everything is 2D so Inkscape is used for CAM and perimeter is used as width.
In daily use, this saves huge amounts of time.
The following user(s) said Thank You: Boogie, behai
- Boogie
15 Feb 2025 19:04 - 15 Feb 2025 20:28 #321655
by Boogie
Got some videos (or forum thread) of your setup? It sounds very interesting. Tube cutting subject is attracting:)
Last edit: 15 Feb 2025 20:28 by Boogie.
15 Feb 2025 22:24 #321669
Not much there...
Not much there...
