Remora with STM32H753ZI
1 year 7 months ago #323719 by REAL ELETRIC
I have a STM32H753ZI development board and would like to install remora, would that be possible?
1 year 7 months ago #323865 by scotta
Replied by scotta on topic Remora with STM32H753ZI
The work for the H7 series is very close to ready. The core code is running and has been updated with a lot of refactoring. I wanted to take this opportunity to get the TMC SPI drivers incorporated, which is what I'm working on at the moment.
github.com/scottalford75/Remora-STM32H7xx
This is the development repo if you would like to have a look. If your board does not use a boot loader than this should get you going. This has been developed on an SKR3 board, so compare your crystal setup and adjust if needed.
Once I'm happy, I'll be adding the bootloader offsets etc in the code.
1 year 1 week ago #337021 by eoverton
Replied by eoverton on topic Remora with STM32H753ZI
How close are you, and how can I help? It's been three or four years since I worked on an ST ARM core, but I do work in the embedded world all the time, and I'm happy to be of assistance. With a little bit of digging, I can probably even find my old ST background debug dongle and the tools to support it.
I presently have a strong interest in seeing this project through to completion. I have been standardizing my computer controlled systems on a Bigtreetech Manta M8P board, which basically is a breakout board for a Raspberry Pi CM4 with an ST32H723ZET6 on it to run the lower-level stuff. I've had very good luck with it using it for Klipper/Mainsail/Crowsnest to run a 3D printer. And since the stepper drivers I want to use to drive the motors on my milling machine drop right in, I'd like to bridge LinuxCNC to it. The higher current drivers (like variants of the TMC5160) use SPI, so I'd need that driver. And it'd be nice to be able to poll a few GPIO's so I can move the mill bed with a joystick for setup. But it shouldn't be *that* difficult, I don't think.
Just let me know if/how I can contribute.
1 year 6 days ago #337244 by scotta
Here you go
github.com/remora-cnc/Remora-STM32H7xx-PIO
It even has TMC5160 support. Work has slowed a bit as we're porting over the F4, but the H7 is running.
1 year 5 days ago #337259 by eoverton
You da man! An H7 and TMC5160 combination should get me up and going. For starters I'm just going to control x, y, and z-axes, but at some point I may add two more drivers for the spindle and a coolant pump.
I've been fiddling with those Chinese-made encoders that they put on everything from calipers to linear rails (which I have bolted to my mill axes for DRO). Eventually it'd be neat to close the loop entirely -- as well as get an old computer joystick wired into a few GPIO's to be able to "jog" the machine manually.
But it all starts with x, y, and z...
Thanks so much!
1 month 2 weeks ago #349626 by adamster112
Replied by adamster112 on topic Remora with STM32H753ZI
hi ive got this working flawlessly on my scylla btt board took 3 days drop us a message on here if u still looking .
Time to create page: 0.059 seconds
