NVEM V5 LINUXCNC REMORA FIRMWARE[SOLVED]
16 Apr 2025 16:22 - 18 Apr 2025 09:49 #326472 by DarkPhoinix
NVEM V5 LINUXCNC REMORA FIRMWARE[SOLVED] was created by DarkPhoinix
Hi all,
I received this board and wanted to insert the remora firmware via segger jtag v8, but I can't find a guide for my model. Where can I find it?
Last edit: 18 Apr 2025 09:49 by DarkPhoinix.
16 Apr 2025 18:42 #326484 by DarkPhoinix
Replied by DarkPhoinix on topic NVEM V5 LINUXCNC REMORA FIRMWARE[SOLVED]
forum.linuxcnc.org/18-computer/44828-rem...-cnc-board?start=380
I found something here, it's not easy to follow so many different cards and so many different topics in a discussion, it's even hard to find them!
17 Apr 2025 18:16 - 18 Apr 2025 09:48 #326534 by DarkPhoinix
I tried to figure out if I see something with pyOCD but I don't understand if I'm using jlink/stlink or links wrong....
Last edit: 18 Apr 2025 09:48 by DarkPhoinix.
02 May 2025 11:19 - 02 May 2025 11:43 #327493 by DarkPhoinix
Solved but I don't know what I DID to unblock the problem, faulty connection pins or next install of rt1052 sdk toll software???
My ST-Link V2 dont have DAP firmware!
Last edit: 02 May 2025 11:43 by DarkPhoinix.
  • nieyinsheng@gmail.com
  • New Member
  • New Member
27 Jun 2025 08:20 #330922 by nieyinsheng@gmail.com
Replied by nieyinsheng@gmail.com on topic NVEM V5 LINUXCNC REMORA FIRMWARE[SOLVED]
Hello, friend. First of all, congratulations on successfully using NVEM V5 on linuxcnc.
I have the same control card as yours, but I read scotta's reply and read the 230 pages, but still can't find a solution, and I don't see a complete process. Can I ask for your help?
09 Nov 2025 09:47 #338105 by archie82
Replied by archie82 on topic NVEM V5 LINUXCNC REMORA FIRMWARE[SOLVED]
Hi DarkPhoinix,
Could you please describe the steps you have used to successfully flash remora as i'm having issues connecting to target using j-link.
Many thanks
archie
Time to create page: 0.248 seconds
