[Unresolved (gave up)]Bios error during lcnc start
- GDTH
01 Jul 2025 18:37 - 08 Jul 2025 17:36 #331071
by GDTH
[Unresolved (gave up)]Bios error during lcnc start was created by GDTH
He.
I have a 5i25 in a HP workstation.
The computer works fine until I want start lcnc. It reboots and gives this error tlp poisend on pci slot.
Does anyone have any idea what is going on?
I did have some difficulty getting the card in.
photos.app.goo.gl/Vi21HjgVt7QMj1yf9
photos.app.goo.gl/Nu3xv5JSHQanxng99
Last edit: 08 Jul 2025 17:36 by GDTH.
- Thank you received: 5209
01 Jul 2025 19:33 #331076
Replied by PCW on topic Bios error during lcnc start
Hard to tell, it might be a connection issue causing a parity error
in that slot or some unknown incompatibility.
Does lspci show the card?
lspci | grep 2718
lspci | grep 2718
- Online
- Thank you received: 6953
01 Jul 2025 19:36 #331077
Replied by tommylight on topic Bios error during lcnc start
Try disabling secure boot and TPM in BIOS.
The following user(s) said Thank You: GDTH
- GDTH
02 Jul 2025 16:23 #331111
by GDTH
Replied by GDTH on topic Bios error during lcnc start
Tpm is disabled
Also the device is visible in:
lspci | grep 2718
lspci | grep 2718
- unknown
- Thank you received: 157
02 Jul 2025 20:40 #331124
by unknown
Replied by unknown on topic Bios error during lcnc start
Seems to be a commonly found issue, HP support forums discuss this quite a bit with various cards.
Might be an idea to google your issue, TLP poisoned, and see if there are any solutions. I wouldn't mention a specific card in your searches to begin with.
My first thought was if the card wasn't on a "whitelist" the PC may refuse to play ball .
- GDTH
08 Jul 2025 17:35 #331537
by GDTH
Thank you for the help. After looking into some more i just grapped a different pc.
- langdons
- Thank you received: 50
08 Jul 2025 20:31 #331542
by langdons
Replied by langdons on topic Bios error during lcnc start
I think the card needs to be installed during the installation.
That way, its kernel module will be loaded during boot-up.
Time to create page: 0.075 seconds
