Mini pc recommendations?
01 Aug 2025 21:38 #332646 by warwickben
Mini pc recommendations? was created by warwickben
I had bought a mini pc from Amazon and I’m not sure if it’s causing latency issues or not ? I’m using a mesa 7i96s .   This is the mini pc I bought.
www.amazon.com/gp/aw/d/B0DNT28BV1?psc=1&...pop_mob_b_asin_title
i shut every thing i could off in the bios including WiFi.
I was using probe basic but I get a latency error and random disconnects .
Could I just switch to a raspberry pi5 16gih version?
02 Aug 2025 00:37 #332653 by PCW
Replied by PCW on topic Mini pc recommendations?
It may be fixable
What servo thread period are you using?
what does:
sudo chart 99 ping -i .001 -q -c 60000 [7i96_ip_address]
report?
(it should run for 1 minute and report timing statistics, [7i96_ip_address] is the IP address of your 7I96S card)
Did you run a standard latency test?
02 Aug 2025 04:34 #332657 by unknown
Replied by unknown on topic Mini pc recommendations?
4GB RPI5 is fine, if you are going to jump that way. But I'd be more inclined to look at the x86 offerings from Odroid. I've been using one for 4 or 5 years without an issue.
02 Aug 2025 06:18 #332660 by warwickben
Replied by warwickben on topic Mini pc recommendations?
I’ll test this out.
I ran the latency test before but wa slightly confused how to read them .
I think part of the issue I’m having is the crappy bios and not being able to disable things .
Time to create page: 0.090 seconds
