pc for linuxcnc using ethercad and Mesa
- kor
18 Aug 2025 07:54 #333612
by kor
pc for linuxcnc using ethercad and Mesa was created by kor
Hi everyone,I’m planning to rebuild one of my CNC mills and would like to use a Mesa 7I76E for axis and I/O, together with a Lichuan LC10E20E EtherCAT servo drive for the spindle.Has anyone here set up a similar configuration and can share their experience with this servo drive?One drawback of this setup is that I’ll need a PC with either three Ethernet ports or two plus Wi-Fi. I’d prefer a fully wired connection (to avoid potential noise issues), I’m looking for recommendations.Do you have suggestions for suitable hardware that would work well with this setup?Greetings from Germany
- Thank you received: 4151
18 Aug 2025 08:19 #333614
Replied by rodw on topic pc for linuxcnc using ethercad and Mesa
There are some nice N150 industrial PC's now with wifi and 4 NIC's that should do the job. Some also have screw terminal RS485 ports too! Insist on Intel NIC's though!
- kor
18 Aug 2025 12:52 #333624
by kor
Replied by kor on topic pc for linuxcnc using ethercad and Mesa
What do you think about the PeeliCeeli N150 and what would be recommendable RAM and SDD size? 16gb RAM and 512 SDD sounds like plenti to me.
Best
kor
Best
kor
19 Aug 2025 07:20 #333658
8 gb will be fine. SSD whatever you want but mostly I've used from 64gb to 256 gb
Time to create page: 0.097 seconds
