The missing firmware module can safely be ignored.
The above post can be safely ignored as well.
Tho if it is something you can do and can afford, I would recommend looking at the riocore/LinuxcncRIO project as that can connect via ethernet, is creates step/direction in hardware and as such only requires a servo thread. Another plus being you don't require a RTAI kernel. Just mentioning as this might be worth investigating. The developer is very generous with his time as well and the project is very active.
Yeah wifi can be an issue sometimes.
It might be worth looking into some of the services that maybe running not is not required for a cnc machine, CUPS is one for example.
