Advantech PCM 9362 freze when opening latency-test
15 Dec 2025 14:07 #340141 by Sekai
Hi.
I have mini pc that i tried to install linuxcnc ( latest version) but horrible latency above 100000.
So i put Debian 12 and install kernal RTai 5.4.258 and linux cnc 2.9.3.
All is good, latency test is like max 24000 with default settings in the bios ( remove everything from the bios i got about 16000 after 2 hours).
The problem sometime the mini pc freeze when running tests (latency-test) so i have to restart.
I thought the bios settings was the culprit so i restore bios to default but the same.
Should i use i different distro or kernel?
  • Moderator
  • Moderator
15 Dec 2025 15:52 #340147 by tommylight
Use this ISO
www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
Boot the PC from it and run the tests in Live mode, meaning do not install, see if it hangs.
15 Dec 2025 23:28 #340170 by unknown
Considering the Atom N450 is a single core CPU I'm unsure how isolating a core that doesn't exist would work.
You may get better latency if you disable Hyperthreading.
I'm assuming you are going to use the parallel port.
15 Dec 2025 23:47 #340172 by Sekai
I used last night the iso from youre post
www.forum.linuxcnc.org/9-installing-linu...-rtai-and-rt?start=0
Linux Mint 19.2 with the bios settings off (single core) RTai
Run it like 2 hours and it never froze.
And the latency was about 12000
15 Dec 2025 23:48 - 16 Dec 2025 00:56 #340173 by Sekai
I explain above that with every settings off the difference is about 5000-7000
Edit: Anyone know how to use gpio on the board?
Edit 2: i really hate this style off editing of the forum.
Last edit: 16 Dec 2025 00:56 by Sekai.
  • Moderator
  • Moderator
16 Dec 2025 05:25 #340183 by tommylight
Use this ISO
Literally what I said in my post before it "mysteriously" disappeared into thin air.
(no offense to you)
Sigh...
1. You literally repeated my already existing post
2. You linked the wrong ISO location for the same ISO
That can and will absolutely raise suspicion.
16 Dec 2025 05:35 #340185 by unknown
I think someone may have raised suspicions many many months ago. But my memory isn't what is used........oh ok there's a monkey
16 Dec 2025 05:39 #340186 by unknown
That would really require delving into the data sheets regarding the gpios, and how and if the Linuxcnc kernel exposed them, they might be available via sysfs. I have doubts about whether they would be realtime capable.
May libgpiod, but not at all sure.
16 Dec 2025 10:35 - 16 Dec 2025 10:36 #340199 by Sekai
Use this ISO
I tried it its above 35000 and it never froze
Last edit: 16 Dec 2025 10:36 by Sekai.
  • Moderator
  • Moderator
16 Dec 2025 11:22 #340203 by tommylight
Nice, that is still very usable.
RTAI kernels always had issues with hardware, mostly graphic where the resolution would be stuck at 640x480 with no options to change it, there are some examples i posted on this forum when i tested some old PC's.
And i do recall one PC would lock after a while or running LinuxCNC, at random, usually once every two to three days.
Time to create page: 0.241 seconds
