Recommend hardware solution for multi rs485 channel?
10 months 6 days ago #340566 by heaven
I have three RS485 devices (each operating at 115200 baud) and one BNO08x IMU, which supports UART at 3,000,000 baud, as well as I2C and SPI.Currently, I am using three USB-to-RS485 adapters and one USB-to-UART adapter to connect these devices. This setup is bulky and inconvenient.I am looking for a more integrated solution, such as a single controller or I/O board, that can communicate with all these devices independently and reduce cabling and USB usage.Any recommendations?
10 months 5 days ago - 10 months 5 days ago #340569 by NWE
Depends partly on how much data each device needs to transmit/receive, and how often. Theoretically, rs485 can multi-drop a large number of devices. I have used rs485 almost strictly via modbus protocol, but I see you do not mention modbus.
Using modbus rtu (rs485) with the mb2hal component, I was able to operate 1 VFD per converter/adapter. I was reading/writing approximately 16 parameters per VFD several times per second. I could not reliably run 2 VFDs on one converter. It seemed I was pushing the limits on bandwidth. But I had it running a lot slower - I think it was 9600, I needed that for better interference tolerance.
I used the ebyte NA111 ethernet bridge. They seem ok. Maybe a bit sensitive to interference. (I was using them in a large cabinet with one 30hp, one 10hp, two 5hp, and one 3hp 480VAC VFD, so there was plenty interference available and they've been running relatively reliably since about 4 month ago when they started using it.)
I also tried using the ebyte NE2-D11 but was very disappointed with it. It was so sensitive to interference it did not work with the Allen Bradley VFD I tried to interface. Well, it worked, but froze every time, the instant the VFD was started. I want to try it sometime on a sensor, or maybe even multiple sensors, I expect it might be fine for that.
I also have on another LinuxCNC installation a cheap USB to rs232 converter reading a position sensor about 50x per second nearly continuously since about 2016.
Last edit: 10 months 5 days ago by NWE.
The following user(s) said Thank You: heaven
10 months 4 days ago #340640 by heaven
The system utilizes three RS485 devices configured in Auto-send mode rather than the standard Query/Response mode to achieve high-speed data transmission. Each device autonomously broadcasts data packets at a 1ms interval. To ensure simultaneous data acquisition and prevent bus contention, right now the solution employs three independent USB-to-RS485 adapters.
I'm looking to move away from USB interfaces due to noise sensitivity and latency concerns at high speeds. I need a more industrial-grade solution that can handle three simultaneous 1ms RS485 streams without data corruption.
The following user(s) said Thank You: NWE
10 months 4 days ago #340642 by rodw
Time to create page: 0.157 seconds
