- Thank you received: 15
MB2HAL example with cheap 16I/16O 24v 'Geroosaty' Modbus boards over RS485
- freemoore
- Topic Author
9 months 4 weeks ago #341021
by freemoore
MB2HAL example with cheap 16I/16O 24v 'Geroosaty' Modbus boards over RS485 was created by freemoore
Hi all.
This is currently working at dining-table levels, but will (hoepfully) become part of a Morbidelli Author 503 retrofit. I haven't found many examples of working mb2hal .hal and .ini files and had a bit of a time getting it all to work, so wanted to post results/a simple guide now that it does. The Morbidelli wants somewhere near 60 inputs/90 outputs and the budget is tight, hence going for the cheapest available:
Geroosaty UM72 board, model number on the board is N4D3E16. These were about £18 each.
Waveshare's USB to RS485 converter based on CH343G and SP485EEN chips, for about £15.
Linuxcnc version is 2.9.8.
I've attached .ini and .hal files. Note that modbus_io.ini is not a separate config file for lcnc but the config file for the mb2hal component.
The board is 16I/16O, 24v, and has SlaveID settable by dip switches:
board 1 has A0 ON and A1-5 OFF for SlaveID 1,
board 2 has A0 OFF, A1 ON, A2-5 OFF for SlaveID 2.
I found some docs which suggest that the baud rate can be changed to 19200 but default is 9600. Wiring: A and B were correctly marked and wired A to A, B to B; GND was attached to the GND of the 24v psu.
I didn't have much success with modbus functions other than 03 or 06; other functions I could get to show up in hal configuration, but either not work or work in a way I couldn't use, hence the weighted_sum components. Notes there: weighted_sum doesn't seem to work with the 'names=' option, just numbered instances. Invoking 'weighted_sum' instances are referred to by 'wsum.0, wsum.1' etc. and when you add them to the servo thread, you add 'process_wsums'. Also when setting up the bits and their weights, it doesn't like the form 'wsum.01.bit.01.weight' but worked when 'wsum.1.bit.1.weight' was used.
I hope reading my config files helps someone else with this setup! Spent a whole day trying to get it to work with either one of two identical but ~15 year old rs485-usb adapters, eventually binned them and had the waveshare one working in a few minutes, once it arrived. Happy New Year all
Andy
Andy
The following user(s) said Thank You: SOLD, michaeln
- freemoore
- Topic Author
9 months 4 weeks ago - 9 months 4 weeks ago #341023
by freemoore
Replied by freemoore on topic MB2HAL example with cheap 16I/16O 24v 'Geroosaty' Modbus boards over RS485
Attaching what documentation I could find, though these refer to the boards having baud rate jumpers, which mine did not.
Last edit: 9 months 4 weeks ago by freemoore. Reason: mistake made when trying to attach files
Time to create page: 0.047 seconds
