TTL to differential converter (STEP / DIR / ENABLE)
- Asymmetrisch
29 May 2026 01:24 #346724
by Asymmetrisch
TTL to differential converter (STEP / DIR / ENABLE) was created by Asymmetrisch
Hello everyone,are there any breakout board to convert TTL signals (3.3 V to 5 V) into differential signals for motor controllers?
I found a converter that was specifically made for that, but unfortunately it’s not available in Germany:
www.cnc4pc.com/shop/c72-c72-differential..._hygKwfclSAuFTXaBSfB
Thanks and best regards,
Gerhard
Gerhard
- andrax
- Thank you received: 84
29 May 2026 06:07 #346728
by andrax
Replied by andrax on topic TTL to differential converter (STEP / DIR / ENABLE)
du brauchst ein TTL zu RS422 Konverter.
Da gibt es jede Menge bei Amazon
- Asymmetrisch
29 May 2026 07:25 #346733
by Asymmetrisch
Replied by Asymmetrisch on topic TTL to differential converter (STEP / DIR / ENABLE)
Ah ok, vielen lieben Dank!
Das sind dann die Konverter mit dem MAX490, und hier dann nur TXD, Y und Z (Senden) anschließen, richtig?
- andrax
29 May 2026 07:39 #346734
by andrax
Jupp,
txd = transmid Data
rxd = receive data
du willst ja nur Senden, also txd
Board ist eigentlich egal, z.b. das hier:
Amazon
txd = transmid Data
rxd = receive data
Amazon
- Asymmetrisch
29 May 2026 08:35 #346735
by Asymmetrisch
Gibt es so eine Lösung evtl. auch gleich mit mehreren Kanälen?
Da kommen ja doch einige Module zusammen bei 3 oder 4 Achsen...
- Thank you received: 5336
29 May 2026 12:39 - 29 May 2026 16:02 #346742
Replied by PCW on topic TTL to differential converter (STEP / DIR / ENABLE)
The conversion interface parts depend on the signal levels needed.
For RS-422 (going into a line receiver on the drive ) where 3V signals into a load are OK,
any RS422 driver will work (say 26LS31 equivalent for 4 channels/chip)
If you wish to drive optocoupled drive inputs that expect 5V signals, you would need
a driver with 5V outputs. AFAIK the only 4 channel RS-422 drivers that do this are
the ISL32174,ISL34172 and MAX3042 (The MAX parts are expensive)
Another option for 5V signals is to use a combination of ACT driver chips with inverting
and non-inverting outputs, say a 74ACT540 and a 74ACT541.
Last edit: 29 May 2026 16:02 by PCW.
The following user(s) said Thank You: andrax
- andrax
29 May 2026 13:30 #346744
by andrax
Also ich hab mal geschaut.
Standartmäßig gibt es meistens max 3 Kanal für die typischen ABZ Encoder.
Gegenfrage: was hast du vor, evtl. gibt es eine andere Lösung?
- Asymmetrisch
30 May 2026 00:22 #346761
by Asymmetrisch
I have several motor controllers that are driven by differential signals (CLK, #CLK, DIR, #DIR) – the inputs (5V, Ri = 120 Ohm) are not optically isolated. At first glance, it seems that controlling it with my Mesa 7i76EU works perfectly.
For testing purposes, I'd like to use the parallel port or possibly a RP2040 – in addition, I have a "Benezan Mini Breakout Board" left over from a previous setup that I could use.
It would be great if there were a solution for this.
30 May 2026 10:27 #346773
For testing purposes with just a parallel port, you could use 2 pins for one signal and invert one in hal
to get differential signals.
As long as the output bits come from the same physical port (say PP pins 2..9), and the hal addf
order and thread is correct. the outputs will change simultaneously.
- Asymmetrisch
03 Jun 2026 12:18 #346876
by Asymmetrisch
Would this change in the hal for parallel port pin 2/3 be correct?
loadrt not count=1
addf not.0 base-thread
net xstep stepgen.0.step => parport.0.pin-02-out
net xstep => not.0.in
net xstep-neg not.0.out => parport.0.pin-03-out
loadrt not count=1
Time to create page: 0.117 seconds
