- Thank you received: 10
Testsoftware for Hardware?
- Holzwurm56
- Topic Author
2 months 5 days ago #349219
by Holzwurm56
Testsoftware for Hardware? was created by Holzwurm56
Hello,
for space reasons, I would like to control my machine using a laptop and a Mesa 7I96 card. Is there perhaps a test program that can identify the laptop/PC's system components? Something like the Windows Device Manager, where you could disable unnecessary devices. You don't need a sound card, battery management, Bluetooth, etc., to control the machine.
Hans
Hans
2 months 5 days ago #349222
Replied by tommylight on topic Testsoftware for Hardware?
forum.linuxcnc.org/18-computer/54369-use...mesa-ethernet-boards
Be aware that the same model laptops might not work due to variety of included hardware.
- Holzwurm56
- Topic Author
1 month 4 weeks ago #349460
by Holzwurm56
Replied by Holzwurm56 on topic Testsoftware for Hardware?
Hello,
I’d like to try LCNC again on a different PC. Is there perhaps a mini live ISO with a real-time kernel—available on a USB stick or DVD—that contains only the latency test? That way, I could test the PCs beforehand rather than wiping everything, installing LCNC, and then finding out it doesn't work. Thanks,
Hans
Hans
1 month 4 weeks ago #349467
Replied by rodw on topic Testsoftware for Hardware?
Yes, the installer is also a live system so run it up, select live and run your tests It won't save any settings between sessions so I just usually install Linux and test on the PC itself.
1 month 4 weeks ago #349470
You can do all that with the official ISO.I’d like to try LCNC again on a different PC. Is there perhaps a mini live ISO with a real-time kernel—available on a USB stick or DVD—that contains only the latency test? That way, I could test the PCs beforehand rather than wiping everything, installing LCNC, and then finding out it doesn't work. Thanks,
Hans
Time to create page: 0.047 seconds
