Configuring SMI ... file not found?
- Mick
09 Jan 2011 00:49 #6560
by Mick
Configuring SMI ... file not found? was created by Mick
I am trying to follow the SMI modification guide as posted on the Wiki. I can't find "rtapi.conf" file. I can get to /usr/local/etc but no farther.
My installation was from the new CD and everything went smooth. I am still trying to improve my latency numbers and want to do the SMI mod. but the Wiki instructions don't work for me.
Has anyone had success following the Wiki?
- alex_joni
09 Jan 2011 09:04 #6563
by alex_joni
Replied by alex_joni on topic Re:Configuring SMI ... file not found?
from wiki.linuxcnc.org/cgi-bin/emcinfo.pl?FixingSMIIssues
"you need to edit a couple lines in /etc/emc2/rtapi.conf"
- Mick
09 Jan 2011 17:16 #6578
by Mick
Replied by Mick on topic Re:Configuring SMI ... file not found?
/etc/emc2/rtapi.conf does not exist in my install?
- Thank you received: 4992
10 Jan 2011 12:53 #6598
Replied by andypugh on topic Re:Configuring SMI ... file not found?
Do you have run-in-place installation?
find / -name rtapi.conf
Might be instructive. I found I had three due to a rather complex installation history.
If you do have a Run-in-place system you will find that every time you recompile then your rtapi.conf gets overwritten from the rtapi,in template file. This is annoying.
- Rick G
- Thank you received: 155
10 Jan 2011 12:56 #6599
by Rick G
Replied by Rick G on topic Re:Configuring SMI ... file not found?
Did you try...
Open a terminal then type
sudo gedit
Then browse to find the file?
Rick G
sudo gedit
Rick G
- Mick
10 Jan 2011 20:02 - 10 Jan 2011 20:03 #6603
by Mick
OK sorry, It is a Linux newbe problem. I now have the "sudo edit" GUI on my desktop and have opened "rtapi.conf"
The first line reads:
# DO NOT EDIT THIS FILE !
The wili does not talk about renaming the file? Should I just make a backup, then edit?
I am a 68 year old retired EE who spent 40+ years in machine controls so I may be able to contribute in a year or so. LOL
Last edit: 10 Jan 2011 20:03 by Mick.
- Rick G
10 Jan 2011 21:07 #6604
by Rick G
It is always a good idea to make a backup file. You can just save it with a new name then edit the original, or save it somewhere else before editing it. Be sure to follow the steps carefully. Remember linux is case sensitive.
Glad to have you onboard. It only gets easier as you go.
Rick G
Rick G
