Can a USB Display Link be used as a second scree?
- otto_pjm
04 Feb 2011 05:35 #6985
by otto_pjm
Can a USB Display Link be used as a second scree? was created by otto_pjm
So I saw these and thought, that if you could run Axis on the main system screen, and touchy on the secondary display, that is right on the machine, that would be a pretty slick setup.
So can Display Link monitors be used with EMC?
This looks promising
libdlo.freedesktop.org/wiki/
Can Axis and Touchy both be active and running at the same time? Or can axis have a floating panel that lives on and responds to a touch screen?
I'm looking at something like this, don't have one to test though.
www.mimomonitors.com/
Pete
Pete
- Thank you received: 5015
07 Feb 2011 11:22 #7041
Replied by andypugh on topic Re:Can a USB Display Link be used as a second scree?
If the monitor can be used with Linux then there is no reason it couldn't be used with EMC2. I have never tried it, but assume that Ubuntu can support multi-monitor setups.
People have used dual-GUIs with EMC2, but it is also possible to have a free-floating PyVCP or GladeVCP panel linked to Axis which could be located on a second monitor.
- otto_pjm
09 Feb 2011 01:39 #7085
by otto_pjm
Replied by otto_pjm on topic Re:Can a USB Display Link be used as a second scree?
Excellent, thanks Andy,
When I have the time and funds to play around I'll check it out.
Pete
Pete
Time to create page: 0.071 seconds
