10.04 Almost unusable on recent pc build
- prcdslnc13
05 Apr 2011 16:48 #8591
by prcdslnc13
10.04 Almost unusable on recent pc build was created by prcdslnc13
I recently built a pc to run 10.04 and EMC2 from linuxcnc.org I havent even gotten to the point of trying out EMC2 on this machine because Ubuntu runs so slow. The build spec's are as follows:
www.geeks.com/details.asp?inv...714-CEL24-PB-R MS-6714 mobo
Intel 2.4ghz celeron processor
2x512 PC-3200 patriot ram
using integrated graphics
40gb Maxtor IDE hd
I installed using the live CD downloaded from linuxcnc.org and Ive used that same cd multiple times so I know that's not my issue.
Now to my problems. The computer runs, just very very slow. Opening 2 web pages at the same time takes 2-3 minutes, and if there is a lot of pictures or content there's no point in trying. Running EMC2 works ok, but if I open a complex program in the viewer all bets are off.
Do you guys have any ideas?
40gb Maxtor IDE hd
- BigJohnT
- Thank you received: 1176
05 Apr 2011 17:30 #8600
by BigJohnT
Replied by BigJohnT on topic Re:10.04 Almost unusable on recent pc build
Do you have the minimum Ubuntu system requirements?
help.ubuntu.com/community/Installation/SystemRequirements
- prcdslnc13
05 Apr 2011 17:35 #8601
by prcdslnc13
Replied by prcdslnc13 on topic Re:10.04 Almost unusable on recent pc build
Yes, I even have the recommended requirements. The only thing I can think of is its maybe my video holding me back.
- Thank you received: 4966
06 Apr 2011 16:51 #8651
Replied by andypugh on topic Re:10.04 Almost unusable on recent pc build
I am guessing that it isn't really an IDE drive?
I wonder if you have a bad memory dimm. It might be worth trying with just one, then the other one.
- prcdslnc13
06 Apr 2011 17:35 #8654
by prcdslnc13
The memory is a good thought, I not tried that yet. I'll try that tonight.
I am using an IDE drive. No sata ports, and its from before PATA.
- BigJohnT
06 Apr 2011 17:44 #8655
by BigJohnT
You might want try the 8.04 LiveCD on older hardware...
- prcdslnc13
06 Apr 2011 17:49 #8656
by prcdslnc13
Can 8.04 be updated to the Current EMC2 version?
- BigJohnT
06 Apr 2011 17:56 - 06 Apr 2011 17:58 #8657
by BigJohnT
Last edit: 06 Apr 2011 17:58 by BigJohnT.
06 Apr 2011 19:04 #8658
I have been using 2.5 (development version) on Hardy for months.
- prcdslnc13
06 Apr 2011 23:39 #8664
by prcdslnc13
looks like that pc just wasn't worth the time. I threw one together from parts in my junk box and its running 10.04 like a bat outta hell Here's the specs
AMD Athlon 2.2ghz
1gig ddr-333
ati x300 video card
same hard drive
screams and has literally a quarter of the jitter rate. Thanks for the help guys!
AMD Athlon 2.2ghz
1gig ddr-333
ati x300 video card
same hard drive
Time to create page: 0.204 seconds
