Will this be a good choice to run EMC2 on?
- Meduza
07 Apr 2011 12:14 #8670
by Meduza
Will this be a good choice to run EMC2 on? was created by Meduza
I have gotten a few Intel rack mounted servers for free, and wonder if you think this is a good option to run EMC2 on for my mill and my lathe?
The servers are of this series and have processors at about 2,8Ghz and 2gb RAM.
www.intel.com/cd/channel/reseller/apac/e...-e/feature/index.htm
- BigJohnT
- Thank you received: 1175
07 Apr 2011 12:40 - 07 Apr 2011 12:41 #8672
by BigJohnT
Replied by BigJohnT on topic Re:Will this be a good choice to run EMC2 on?
Load the LiveCD and run the latency test to see...
Also you might want to check to see if they meet the minimum requirements for Ubuntu... a quick google will find that page.
Last edit: 07 Apr 2011 12:41 by BigJohnT.
- Thank you received: 4966
07 Apr 2011 13:15 #8674
Replied by andypugh on topic Re:Will this be a good choice to run EMC2 on?
I have an Intel rackmount on my mill/lathe combo. It works fine, but does need the SMI patch applying to avoid a latency spike every 64 seconds.
Mine is a different model (with dual original xeons) so you might find you have no issues, or different ones.
- Meduza
08 Apr 2011 07:58 - 08 Apr 2011 08:00 #8693
by Meduza
Replied by Meduza on topic Re:Will this be a good choice to run EMC2 on?
Minimum requirements shouldn't be a problem, as i said the processor is over 2,5Ghz, RAM over 1GB and hard drives is at least 74GB UltraSCSI320 10k drives, so so that should not be a problem either, and it got a graphics output capable of 1024x768, no probs, it also got a real paralell port and a PCI slot where i can put one more or maybe a MESA card.
I have not been able to move any of the computers home to test out, they are right now stacked on a pallet in a friends workshop.
Last edit: 08 Apr 2011 08:00 by Meduza.
08 Apr 2011 09:07 #8694
Meduza wrote:
Minimum requirements are rarely a problem, EMC2 runs on very modest hardware. The problem is that even very high-end hardware can often have latency problems.
Unfortunately the only way to really know is to run the latency tests from the LiveCD and test.
Minimum requirements shouldn't be a problem, .
- Meduza
08 Apr 2011 12:28 #8702
by Meduza
OK, i'll guess i just have to take one home in next week and try to install EMC2 and run the latency test then
The Minimum requirements was a answer to BigJohnT's comment about checking the minimum requirements.
Time to create page: 0.079 seconds
