Embedded EMC2
- epileftric
16 Apr 2011 23:50 #8989
by epileftric
Embedded EMC2 was created by epileftric
I'm looking forward to start working on the project for creating an embedded system running EMC2 alone. It will be runing on top of a embedded linux with the RTAI patched kernel.
I've been reading the source code and documentation for a few days, my question is the following in order to manage the outputs in my custom hardware, the only thing I need to do is to create a HAL driver to drive it according to it's own specifications of the physical pins, right? Did I get it?
Thanks.
Thanks.
- Thank you received: 2154
17 Apr 2011 00:32 #8990
Replied by cmorley on topic Re:Embedded EMC2
yes. either in C or with EMC's comp.
- BigJohnT
- Thank you received: 1175
17 Apr 2011 11:11 #8999
by BigJohnT
Replied by BigJohnT on topic Re:Embedded EMC2
Take a look here:
www.linuxcnc.org/docview/html/hal_comp.html
download the source with git and look at the other comps in /src/hal/components
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Installing_EMC2
- epileftric
19 Apr 2011 12:27 #9077
by epileftric
Replied by epileftric on topic Re:Embedded EMC2
Thanks for the support! I'll be here again in some time when I start codding!
