Strange lathe motion.
15 years 3 months ago #11321 by andypugh
Replied by andypugh on topic Re:Strange lathe motion.
The thing is, we still have no idea what the original problem is..
15 years 3 months ago #11322 by aike
Replied by aike on topic Re:Strange lathe motion.
SOLVED!
The error:
N39 G3 X54.7 Z40.2 I2.2 K0. - Original
N39 G3 X54.9 Z40.2 I2.2 K0. - HAS TO BE
so as the starting point calculated from previos position:
N37 G2 X50.5 Z36.5 I0. K5.
N38 G1 Z38.
X=50.5
Z=38
The end point for X = 2.2*2+50.5=4.4+50.5=54.9
The end point for Z = 38+2.2=40.2
Hence the G3 command looks like:
The lathe behave itself strange in THIS point.
Please, correct the sintax interpritator in EMC 2.5. PLEASE!
15 years 3 months ago #11325 by forhire
Replied by forhire on topic Re:Strange lathe motion.
Glad you solved it.
While I was pouring over your original code I found that N15 and N56 appear to be missing the decimal point also. It's a small thing.
N15 G0Z37.X21
N56 G1X80
Should likely be:
N15 G0Z37.X21.
N56 G1X80.
Does emc2 interpret those values as x21 or x0.0021?
15 years 3 months ago #11326 by andypugh
N15 G0Z37.X21.
N56 G1X80.
I don't think that those decimal points should be there at all.
X21 is fine, and means move X to 21 (mm in this case).
To move to X=0.0021 you put X 0.0021.
I see no point using decimal points when there are no places of decimals.
15 years 3 months ago #11327 by forhire
Thanks for clarifying that. My Mori requires the decimal... so that is how my plotter is setup. B)
