- Thank you received: 3
Thank you for explain, I will insert this sequence of command in the header of g-file.While I can't test here I do know that even if you have something in your RS274NGC_STARTUP_CODE it can be overwritten by any g code file or a MDI command. So if you ran another file that changed them even just running an example file it can change your current modes. Things like that should always be in the preamble of your g code file.
Do you mean the problem occurs the 3rd time you run the code?
The error occures randomly.
Looks like the error in interpolation (float point operation) caused in not controlled moving.
I think so
The program becomes to live its own life
