Strange lathe motion.
- forhire
09 Jul 2011 21:29 #11325
by forhire
Replied by forhire on topic Re:Strange lathe motion.
Glad you solved it.
While I was pouring over your original code I found that N15 and N56 appear to be missing the decimal point also. It's a small thing.
N15 G0Z37.X21
N56 G1X80
Should likely be:
N15 G0Z37.X21.
N56 G1X80.
Does emc2 interpret those values as x21 or x0.0021?
N15 G0Z37.X21
N56 G1X80
Should likely be:
N15 G0Z37.X21.
N56 G1X80.
09 Jul 2011 21:34 #11326
Replied by andypugh on topic Re:Strange lathe motion.
forhire wrote:
I don't think that those decimal points should be there at all.
X21 is fine, and means move X to 21 (mm in this case).
To move to X=0.0021 you put X 0.0021.
I see no point using decimal points when there are no places of decimals.
N15 G0Z37.X21.
N56 G1X80.
- forhire
09 Jul 2011 21:42 #11327
by forhire
Thanks for clarifying that. My Mori requires the decimal... so that is how my plotter is setup.
Time to create page: 0.294 seconds
