differences between NC code & G code
16 years 10 months ago #1315 by Skullworks
If the spline is output by your CAD/CAM as a series of short line segments then EMC will handle it just fine for the most part. There can be cutter comp issues if going into an inside corner.
Also during actual cutting you will need to use the G64 p with a tolerance value or EMC may bog down.
16 years 9 months ago #1574 by iriaf
when i try to run this code shows me an error:
G01 X10 Y10 Z10
why EMC can not excute this code?
is,nt there any way to excute it?
16 years 9 months ago #1576 by acemi
Did you give a feed rate? For example:
F100
G01 X10 Y10 Z10
or
G01 X10 Y10 Z10 F100
Time to create page: 0.251 seconds
