Wrong G81 Z retract
23 Aug 2011 11:22 - 23 Aug 2011 11:25 #12666 by ArcEye
Replied by ArcEye on topic Re:Wrong G81 Z retract
andypugh wrote:
I wonder if the % at the beginning is cancelling a modal G98 code somehow?
I thought that G99 was the default behaviour unless you specifically programmed a G98?
There is no G98 or G99 in plasdoms code and my simulator shows G99 as the active G-Code.
The movement I saw coincides with that retraction model.
However I think I have solved the mystery.
The code does not start anywhere, just jumps straight into G81.
If you place Z at 2" before calling G98, the program retracts to Z2 every time after drilling a hole
eg
g17 g20 g40 g49 g54 g80 g90 g94
G0 Z2
G98
g81 f8 x.225 y-.125 r.08 z-.02
Last edit: 23 Aug 2011 11:25 by ArcEye.
  • piasdom
  • piasdom's Avatar Topic Author
  • User is blocked
  • User is blocked
23 Aug 2011 11:33 - 23 Aug 2011 11:33 #12667 by piasdom
Replied by piasdom on topic Re:Wrong G81 Z retract
Cool, but this is an old file i use many times. never changed anything
til it went coco:). i added the below to the start. retracts to where it
should but plot is wrong on bottom holes. shows z0, but runs at z-.75.
added g99 to below and plot shows correct path.
g17 g20 g40 g49 g54 g80 g90 g94 g92.1
(C-Drilling)
m6 t5
g0 x.1 y.1
z.2
p.s. i have no % in file
Last edit: 23 Aug 2011 11:33 by piasdom.
  • piasdom
  • User is blocked
  • User is blocked
23 Aug 2011 11:47 #12668 by piasdom
i tried g98 below and the plot changed back to wrong retract on
bottom holes. and all holes retract to 2". if g98-99 are for z retract,
what is the 'r' for in g81? used g81 for two years now, first time
all goes coco:)
G0 Z2
G98
  • piasdom
  • User is blocked
  • User is blocked
23 Aug 2011 11:54 #12669 by piasdom
ran dmesg and found below. this could be my trouble ?
[ 195.229143] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 195.229163] This Message will only display once per session.
[ 195.229164] Run the Latency Test and resolve before continuing.
[ 676.316260] PNPBIOS fault.. attempting recovery.
[ 676.316263] PnPBIOS: Warning! Your PnP BIOS caused a fatal error. Attempting to continue
[ 676.316265] PnPBIOS: You may need to reboot with the "pnpbios=off" option to operate stably
[ 676.316267] PnPBIOS: Check with your vendor for an updated BIOS
[ 676.316270] PnPBIOS: set_dev_node: unexpected status 0x3a
[ 676.316272] probe_parport 00:0b: disable failed
[ 676.396251] RTAI[math]: unloaded.
Attachment dmesg.txt not found
23 Aug 2011 12:51 #12670 by ArcEye
Another thing to sort out, but I can't see how, not going to change how G81 picks up the Z axis position.
What I found goes back to what Andy said at the beginning
My impression was that it would always retract to the last G1 Z position, not anywhere jogged to. I didn't check G0.
It looks like G81 uses the last linear move to a position for Z and does not read it's actual position.
It would anticipate a move like G0 X0 Y0 Z2 as a precursor to any G81 canned cycle
If you move to a location by jogging and then run G81, as effectively your program does, it has no Z position set by a move and it acts as observed.
  • piasdom
  • User is blocked
  • User is blocked
23 Aug 2011 13:09 - 23 Aug 2011 13:12 #12671 by piasdom
just wondering if the developers changed something or if something
changed on my comp i don't know about. if i use below, file runs as should.
doesn't use .2" as retract.. uses .08"
g17 g20 g40 g49 g54 g80 g90 g94 g92.1 g99
(C-Drilling)
m6 t5
g0 z.2
and i seen epp somewhere and saw it today in the bios.
selections;
normal
bi-directional
ecp
epp
ecp & app
set at bi-dir.. does this matter to emc or is this
for printers ?
kenneth
Last edit: 23 Aug 2011 13:12 by piasdom.
23 Aug 2011 13:36 #12673 by BigJohnT
Replied by BigJohnT on topic Re:Wrong G81 Z retract
Kenneth,
I ran the file on the 2.4.2 Axis sim and got the expected retract points... I'll go down to the beer cave and see what 2.5.x does.
  • piasdom
  • User is blocked
  • User is blocked
23 Aug 2011 13:44 - 23 Aug 2011 13:45 #12674 by piasdom
Thanks John,
maybe i should go back to 2.4 ?
kenneth
p.s. got 2.5 to use glade, but somein rong.
don't really need now.
Last edit: 23 Aug 2011 13:45 by piasdom.
23 Aug 2011 13:49 #12675 by BigJohnT
Nope, runs fine on 2.5 too.
On the DRO tab do you have a leftover G92 offset that was not cleared by some other program that you ran?
23 Aug 2011 13:57 #12676 by ArcEye
and i seen epp somewhere and saw it today in the bios... set at bi-dir.. does this matter to emc or is this for printers ?
BIOS should set the parport as EPP for emc
Bi-directional is for older printers and devices to be able to report back ink levels, confirm ready for next data packet etc. as far as I am aware.
Was overtaken by IEEE 1284 ECP for most new printers.
Whilst EPP is bi-directional, there is a different protocol.
Time to create page: 0.119 seconds
