Hi anyone
new (and quite inexperienced) to EMC2, I have a question related to the optimization of the g-code for mass production. I have a router that will basically run same 5-6 files depending on the demand i have for each model. What i intend to do is to get an optimized g-code so that the working time for my operations is the shortest.
I refer here to the order of the cuts - for example with artcam and mach3 the traveling times were very long and useless, adding a lot of time.
Unless anyone can suggest a CAM software that optimizes for EMC2, is there a possibility at least to manually select the order of the cuts? i have about 50, and i think i can manually select them in the best order for the least travel.
