G-Code to turn machine OFF
- MasterSpoon
28 Jun 2019 02:25 #138078
by MasterSpoon
Replied by MasterSpoon on topic Re:G-Code to turn machine OFF
Thank you for the prompt replies, making progress
I created a M130 code with
It works the first time but then doesn't work again until you close and reopen LinuxCNC, Even when it's working however it only toggles machine power (F2) where I'm trying to toggle E-stop (F1)
I found this
wiki.linuxcnc.org/cgi-bin/wiki.pl?Halui
estop:
halui.estop.activate bit //pin for setting Estop (emc internal) On
halui.estop.reset bit //pin for resetting Estop (emc internal) Off
halui.estop.is-reset bit //pin for displaying Estop state (emc internal) On/Off?
usingIt does exactly what I want however not consistently. I can load LinuxCNC, F1 - Estop, F2 - toggle machine power, F5 - MDI, M130 and does exactly what it should
If I then F1 - Estop, F2 - toggle machine power, M130 a second time the M130 does nothing.
So it works but it only appears to work the first time for each session but won't work a second time. Am I missing something obvious here ?
#! /bin/bash
halcmd setp halui.machine.off 1
exit 0It works the first time but then doesn't work again until you close and reopen LinuxCNC, Even when it's working however it only toggles machine power (F2) where I'm trying to toggle E-stop (F1)
I found this
estop:
using
#! /bin/bash
halcmd setp halui.estop.activate 1
exit 0If I then F1 - Estop, F2 - toggle machine power, M130 a second time the M130 does nothing.
- Thank you received: 2181
28 Jun 2019 02:29 #138079
Replied by cmorley on topic Re:G-Code to turn machine OFF
I would try something like:
halui expects the pin to toggle.
Chris M
#! /bin/bash
halcmd setp halui.machine.off 0
exit 0halui expects the pin to toggle.
Chris M
- MasterSpoon
28 Jun 2019 02:54 #138080
by MasterSpoon
Booya, we have a winner !
Okay so tried that code, didn't work but it led me to the answer
M130M129M300
M129 effectively resets the Pin, but M129 then M130 straight after appears to try too quickly before the M129 has reset the pin and it doesn't work
M300 resets the pin, turns off coolant & spindle, waits 5 seconds for them to spin down then hits the E-Stop
I'm now one step closer to having it all set exactly how I want, thank you for the help
#! /bin/bash halcmd setp halui.machine.off 0 halcmd setp halui.machine.off 1 exit 0
Chris M
M130
#! /bin/bash
exit 0#! /bin/bash
halcmd setp halui.estop.activate 0
exit 0o<m300> sub
m129
M9
M5
G4 P5
m130
m30
o<m300> endsubM129 effectively resets the Pin, but M129 then M130 straight after appears to try too quickly before the M129 has reset the pin and it doesn't work
28 Jun 2019 10:14 #138105
Replied by andypugh on topic Re:G-Code to turn machine OFF
I am surprised that the G-code subroutine continues to execute through e-stop.
Try doing it all in the bash script, but re-set the pins afterwards.
I don't have bash here so can't test this, but the idea is to turn off spindle and coolant, wait 5 secs, toggle e-stop then poll the machine status until e-stop has activated.
Then all the halui pins are toggled back to zero for the next time round.
#! /bin/bash
halcmd setp halui.flood.off 1
halcmd setp halui.spindle.stop 1
sleep 5
halcmd getp halui.machine.is-on
while [ $? = 1]
do
sleep 1
done
halcmd setp halui.flood.off 0
halcmd setp halui.spindle.stop 0
exit 0I don't have bash here so can't test this, but the idea is to turn off spindle and coolant, wait 5 secs, toggle e-stop then poll the machine status until e-stop has activated.
- pl7i92
- Thank you received: 358
28 Jun 2019 10:30 #138108
by pl7i92
Replied by pl7i92 on topic G-Code to turn machine OFF
5-7 seconds of untrou states that is a real whear behavior even on e-stop
E-stop is e-stop
then user shoudt take action non Mcode state changes after this
Why at all shoudt the G-code trigger e-stop
this is mashine and safty issue non g-code related
im with you at M9 M5 M30
the Mashine off as on large printings 24+ hr is here a Realy that shuts the complete power down
g-code mashine issues behavior is real wheard
E-stop is e-stop
- MasterSpoon
28 Jun 2019 13:03 #138115
by MasterSpoon
I gave your code a try as it seemed a bit more elegant then my solution but for some reason the sleep command doesn't work in the bash script.
If I even try justthen the code still runs but it seems to ignore the sleep command and just toggles it off straight away as if sleep wasn't there.
I also tried sleep 5s but no dice either.
If I even try just
#! /bin/bash
sleep 5
exit 0I also tried sleep 5s but no dice either.
28 Jun 2019 13:09 #138116
Try "5s"
Maybe it defaults to nS or something?
- pl7i92
28 Jun 2019 17:39 #138127
by pl7i92
get a
sleep --help
and somtimes the wrong bash sleep versions
sleep --version
sleep --help
sleep --version
- MasterSpoon
29 Jun 2019 00:17 #138143
by MasterSpoon
Replied by MasterSpoon on topic G-Code to turn machine OFF
Ok I feel like an idiot now...
I have a G-code folder that I use to transfer G-code from my main computer to the milling computer, I have then been doing my custom M code files in the linuxcnc/nc_files folder
Forgot that it checks the default folder first, which was the G-code folder and I had a duplicate in there so when I was editing the one in the nc_files folder it wasn't doing anything as it was reading the one from my G-code folder first.
Sleep works fine now that I have solved the operator error.
I was still having trouble with andypugh's script not working, it seemed to work once then when I ran it a second time it wouldn't turn the machine off. I used a simplified and probably not quite as graceful script but doing
seems to do exactly what I want so I will leave it at that for now.
Thanks again for the help
#! /bin/bash
halcmd setp halui.mist.off 1
sleep 5
sleep 1
halcmd setp halui.mist.off 0
exit 0seems to do exactly what I want so I will leave it at that for now.
30 Jun 2019 13:52 #138237
Replied by andypugh on topic G-Code to turn machine OFF
Your version of the script has the potential problem that if the machine takes more than 1 second to respond to the e-stop then it might never see it as the signal then resets regardless of machine state.
I also really do think that machine-off would be better than e-stop.
machine-off should shut down all the amps and stop all motion.
e-stop should be reserved for emergency stops, and probably ought to lock-out a machine re-start unless a hardware button is pressed. (though I confess that nether of my machines have this for the sofware e-stop, only for the hardware stop)
