G-Code to turn machine OFF
7 years 4 months ago #138143 by MasterSpoon
Replied by MasterSpoon on topic G-Code to turn machine OFF
Ok I feel like an idiot now...
I have a G-code folder that I use to transfer G-code from my main computer to the milling computer, I have then been doing my custom M code files in the linuxcnc/nc_files folder
Forgot that it checks the default folder first, which was the G-code folder and I had a duplicate in there so when I was editing the one in the nc_files folder it wasn't doing anything as it was reading the one from my G-code folder first.
Sleep works fine now that I have solved the operator error.
I was still having trouble with andypugh's script not working, it seemed to work once then when I ran it a second time it wouldn't turn the machine off. I used a simplified and probably not quite as graceful script but doing
#! /bin/bash halcmd setp halui.mist.off 1 halcmd setp halui.spindle.stop 1 sleep 5 halcmd setp halui.estop.activate 1 sleep 1 halcmd setp halui.estop.activate 0 halcmd setp halui.mist.off 0 halcmd setp halui.spindle.stop 0 exit 0
seems to do exactly what I want so I will leave it at that for now.
Thanks again for the help
7 years 4 months ago #138237 by andypugh
Replied by andypugh on topic G-Code to turn machine OFF
Your version of the script has the potential problem that if the machine takes more than 1 second to respond to the e-stop then it might never see it as the signal then resets regardless of machine state.
I also really do think that machine-off would be better than e-stop.
machine-off should shut down all the amps and stop all motion.
e-stop should be reserved for emergency stops, and probably ought to lock-out a machine re-start unless a hardware button is pressed. (though I confess that nether of my machines have this for the sofware e-stop, only for the hardware stop)
Time to create page: 0.350 seconds
