Need to turn 90 degs.
19 Jan 2012 18:14 #16949 by cwebs
Replied by cwebs on topic Re:Need to turn 90 degs.
andypugh wrote:
BigJohnT wrote:
linuxcnc.org/docview/2.5/html/gcode/gcod...em_a_id_sec_g10_l2_a
Which says you probably want G10 L2 P0 R90
You could, however, set up G55 (for example) to be your rotated coordinate system, and leave it rotated permanently.
P0 still comes back "P out of range". Oh Well.
19 Jan 2012 18:48 - 19 Jan 2012 18:48 #16951 by andypugh
Replied by andypugh on topic Re:Need to turn 90 degs.
Looks like the docs are wrong, or don't match your version.
If you are in G54 , use P1 and all should be well (I just checked that, and it works)
Last edit: 19 Jan 2012 18:48 by andypugh.
19 Jan 2012 22:47 #16959 by BigJohnT
Replied by BigJohnT on topic Re:Need to turn 90 degs.
Unfortunately the docs are correct but confusing to read... the correction is on the list, thanks for finding the confusion. And my mistake in linking 2.5 docs which support P0 for the current coordinate system. I guess I'm excited about 2.5 fixing to hit the streets and tend to wander over to those docs...
2.4.x docs are here:
linuxcnc.org/docview/html/gcode_main.htm...:G10:-Set-Coordinate
19 Jan 2012 23:10 #16961 by cwebs
Ok. I tried P1 and got no error using Mach3 Sim. But The work peice was not turned 90 degz. I will try in in LinuxCNC tonight. THanks John.
I knew you made that boo boo but was saving your feelings. Carl
19 Jan 2012 23:14 #16962 by BigJohnT
Well the mack sim will be different for sure...
19 Jan 2012 23:15 #16963 by andypugh
You might not see it. I only saw it in the EMC2 sim because the right-arrow started moving the Y axis on-screen
I should have remembered to try 45 degrees, then all arrow keys ought to move both axes…
19 Jan 2012 23:26 #16964 by cwebs
Replied by cwebs on topic Re:Need to turn 90 degs.(Solved)
THe P1 did the trick. It doesn't work in Mach3 Sim but you were right Andy it does work just fine in LinuxCNC. You see John, I knew if you read the man you would be able to do it! Thanks guys, Carl
20 Jan 2012 00:18 #16966 by BigJohnT
Replied by BigJohnT on topic Re:Need to turn 90 degs.(Solved)
Well the statement about jogging is correct in the 2.5 docs :)
25 Jan 2012 16:55 #17128 by cwebs
After we got the G10 going I found this software that changes TXT. file to DXF. and many more. The software is free. It is another cnc controler for USB. I hope this will help other people that need to convert there files. Worked for me with one click! Carl
www.planet-cnc.com/
Time to create page: 0.142 seconds
