Resuming after a stop in a WHILE loop
  • Robo-Dan
  • Topic Author
  • New Member
  • New Member
14 years 9 months ago #17026 by Robo-Dan
Resuming after a stop in a WHILE loop was created by Robo-Dan
Hi guys,
I am producing a large array of parts using while loops and it takes several hours to complete the array of parts. As is always the case, there can be something that goes wrong half way through machining and I have to stop the program. I would like to be able to resume the program where it left off within the while loops, but it always starts back up at the beginning. You can imagine how frustrating that would be.
The rows and columns of my array are written to parameters #21 and #22 and those parameters are used for incrementing my WHILE loops.
After a stop, I've tried manually writing the values of the current part in the array into the MDI (ie. #21 = 2 , #22 =4) and also manually input the offset where the tool should be for the current part. Then selected 'run from here' on the current line inside the while loop. However, the program still just starts over at the beginning of the while loop. Anybody have any ideas as to how I can fix this?
Thanks,
Dan
14 years 9 months ago #17040 by BigJohnT
Replied by BigJohnT on topic Re:Resuming after a stop in a WHILE loop
When run from line was written I don't think loops were part of the code so it does not function well with loops.
Is there a way to restructure your g code so your not restarting inside of the while loop?
14 years 9 months ago #17071 by andypugh
Replied by andypugh on topic Re:Resuming after a stop in a WHILE loop
I have just experimented with the following, and can't make any sense of it.
(debug, #1)
o100 while [#1 LT 4]
o101 while [#2 LT 4]
(debug, #1 #2)
g0 x0
#2 = [#2 + 1]
o101 endwhile
#1 = [#1 + 1]
o100 endwhile
m2
Though one solution might be to write the code like this:
#100 = 2
#101 = 2
#1 = #101
#2 = 1
o103 IF [#101 NE 1]
#2 = #101
#101 = 1
o103 endif
(debug, #1 #2)
g0 x0
#2 = [#2 + 1]
o101 endwhile
#1 = [#1 + 1]
o100 endwhile
m2
Then you can edit the #100 and #101 variables in the code and run from the start.
The "IF" is so that it starts the next Y row from the beginning even if it starts from the middle of this row.
Time to create page: 0.043 seconds
