Error when using circular interpolation on lathe
04 Feb 2012 12:25 #17404 by BigJohnT
This works for me...
g18 g8 g90.1
f3
g01 x1.2815 z-0.1626
g02 x0 z0 i0 k-5.1354
m2
John (off to take a nap)
04 Feb 2012 14:16 #17405 by justinbowser
Replied by justinbowser on topic Re:Error when using circular interpolation on lathe
John,
The light bulb just glimmered a bit! Man, do I feel like a dumb-a$$! I was mixing radius and diameter values. I had a sarge, once, who would have said that's just D...U...M... dumb!
I have the face cutting perfectly and just need to experiment with the bits I have laying around to find a combination of cutter/speed/feed gets me the smoothest possible cut in plexi to keep the hand finishing to a minimum.
Again, thanks for your help and examples that dragged me kicking and screaming toward the light! ;)
Justin
04 Feb 2012 15:18 #17406 by BigJohnT
When I get stuck hand coding an arc I draw it in cad and find the start, end and offset points then it usually works.
For any plastics you want as big as possible chip to pull the heat out of the material, of course that depends on your cutter size and material size. Also use a dead sharp insert like the razor sharp ones for cutting aluminum.
Time to create page: 0.063 seconds
