G92 messing up the coordinate
27 Feb 2012 09:12 - 27 Feb 2012 09:13 #18144 by KenC
Replied by KenC on topic Re:G92 messing up the coordinate
OK.
I did everything exactly as 5.3
& at the end of the procedure both the DRO in the Preview Tab (upper left corner) and the DRO tab both show all axes to be 0.0000
Next, (without homing any axis) I click on MDI tab & issue G92 Z-15 & the DRO in the Preview Tab change to Z:381.00 instantly. but when I click on the the DRO tab, it show all axis to be 0.000
Ken
Last edit: 27 Feb 2012 09:13 by KenC.
27 Feb 2012 09:38 #18149 by BigJohnT
Replied by BigJohnT on topic Re:G92 messing up the coordinate
I'm able to reproduce that here. Seems the DRO tab is not getting updated after a G92 is issued in the MDI if it is not on top (visible) when the G92 is issued while the Preview DRO is updated in every case. If you move an axis while the DRO tab is visible the G92 is updated and shows up.
Is that what your seeing?
27 Feb 2012 09:47 #18150 by BigJohnT
Also, you see 381 because your viewing it in MM... which is configured on the View menu.
27 Feb 2012 21:45 #18165 by KenC
Hi John,
Thanks for looking into this.
This "mess" is driving me nuts...
How do you think it can be solve? or is this a genuine bug?
Regards
Ken
28 Feb 2012 05:29 #18172 by BigJohnT
Which "mess" are you talking about?
28 Feb 2012 05:57 #18174 by KenC
Can not get G92 to assign offset cordinate. & the joint limit get exceeded.
28 Feb 2012 06:13 - 28 Feb 2012 06:23 #18175 by KenC
LOL!!!!
I think I found the problem...
Some time in the pass, a G20 code was issued in my program.... Don't ask me how it get ther but it was there...
A simple G21 solved the whole of my own "mess"...
John, I could had done it without you help... found the clue in " which 'mess' are you talking about"
Edit:
Found that naughty G20 in the default EMC2.4/Axis g-code. I will add a G21 lin in my post processor just to be sure this doesn't happen in the future.
Last edit: 28 Feb 2012 06:23 by KenC.
28 Feb 2012 07:25 #18178 by BigJohnT
I am so glad you sorted that out!
So I gather your set up for millimeters and when you issued the G92 Z15 you were expecting 15mm and you got the conversion from 15 inches to 381millimeters. That would blow your mind... As you have found out a good practice is to put all the settings like units, turning off comp etc. in the preamble of every file. For my lathe my preamble line is something like this:
G7 G18 G20 G40 G49 G54 G61P0.001 G80 G90
28 Feb 2012 08:14 #18181 by KenC
John,
I see G20 & G61. hmmm... trujutory control is something I should put in my preamble line too.
Thanks for the help.
I felt like an idiot when I realised the cause of this G92 episode... a problem which wasn't a real problem BUT I am glad its "solved" :)
Otherwise, I would not had learnt a great deal more on co-ordinate related codes.
I can sleep tonight with peace. :)
I can't thank you more...
Regards
Ken
