Problem with G33.1 and Ver 2.6?
27 May 2012 00:19 #20434 by garymcrobertpdx
Problem with G33.1 and Ver 2.6? was created by garymcrobertpdx
A few days ago I installed version 2.6 it seems to work except when I attempt to use a G33.1
like G33.1 Z-0.750 K0.05 the spindle makes about one rev then the Z axis stops.
I have used HAL Scope to look at the spindle encoder index pulse it appears to be working
fine and G33.1 worked with Ver 2.3
Any idea as to the problem?????
28 May 2012 11:45 #20458 by andypugh
Replied by andypugh on topic Re:Problem with G33.1 and Ver 2.6?
That sounds like it might be expensive.
The sim-lathe sample config has a spindle encoder. Can you see if that shows the same problem? (being a sim it won't break any real-world taps)
The following user(s) said Thank You: joekline9
Time to create page: 0.311 seconds
