Input variable and current possition?
- eslavko
27 Feb 2010 07:23 #2086
by eslavko
Input variable and current possition? was created by eslavko
Hello...
I'm new on EMC2 and have problem...
How to enter some variable in runtime?
eg to gcode stops and ask for some veriable and after that to use it. For example to program stops and ask for radius of circle to make hole for example.
I come from TurboCnc and there was command
Ask #variable ;text prompt
is there something similar?
And other question is how to put current X (or Y..) position into variable?
somethimg like
#1000=X ???
Slavko.
somethimg like
#1000=X ???
Slavko.
- piasdom
- User is blocked
- Thank you received: 9
25 May 2010 08:51 #2999
by piasdom
Replied by piasdom on topic Re:Input variable and current possition?
don't know if you're still looking for an answer but;
to do circle/arcs, you need to use g2 & g3 (cw & ccw)
you can read about them here www.linuxcnc.org/docview/html//gcode_overview.html
as far as x y
g1 f4 x1.5 y2
will make the x move to 1.5 and y to 2
hope this helps.
as far as x y
g1 f4 x1.5 y2
hope this helps.
- eslavko
25 May 2010 10:00 #3002
by eslavko
Replied by eslavko on topic Re:Input variable and current possition?
This seems that is entirely the wrong post.
The question I asked are still in question.
Just how to store position in variable is partialy solved. G30.1 is the answer.
I stil want to put current location (with all offsets as is read from DRO) into variable.
and stil want to enter some variable in runtime.
For example just imagine the drilling went holes array.
I need to enter distance betwen holes and amount of holes in X and Y.
For now I need to open file, edit variables, save file and reopen in axis.
Can be done just is a lot of cliccking instead just entering 3 numbers in prompt.
- piasdom
- User is blocked
26 May 2010 04:43 #3014
by piasdom
the only way axis can get info is to edit the file and reload file in axis or to import a whole file.(which
needs to be edit when changes occur.(IMO)
if you need more indept info, you can go to irc here;
irc.freenode.net
and go to #emc. that's where the developers chat and help others.
irc.freenode.net
Time to create page: 0.711 seconds
