Threadmilling problem
- 109jb
- Thank you received: 15
07 Jul 2012 19:12 #21681
by 109jb
Threadmilling problem was created by 109jb
I was working on a part that I needed to do a bit of threadmilling on and I ran into a problem. First, here is the entire code I was trying to run. X0, Y0 are the center of the already bored hole (0.875" diameter).
G90
G0 X0 Y0 Z0.1
F10
G1 Z0
G1 X-.282
G2 X-.282 Y0 P10 Z-0.625 I.282 J0
G1 X0
G53 G0 Z0
G53 X0 Y0
M02
But this code gives me an error. It says the P-word can't be used with G2, but the manual I have says that is how to do it.
I was able to get the job done by putting the machine in incremental mode just before the G2 line and using a loop (10X) with a line as follows:
G2 Z-.0625 I0.282
I then put it back into absolute mode and finished the program.
What am I doing wrong with the muti-turn helix? I am using LinuxCNC version 2.4.6.
Thanks,
John B.
G90
G0 X0 Y0 Z0.1
F10
G1 Z0
G1 X-.282
G1 X0
G53 G0 Z0
G53 X0 Y0
M02
G2 Z-.0625 I0.282
Thanks,
John B.
- Rick G
- Thank you received: 114
07 Jul 2012 22:10 #21682
by Rick G
Replied by Rick G on topic Re:Threadmilling problem
For what it is worth it works for me on 2.6
You may want to try it after upgrading to 2.5.
Rick G
Rick G
- Thank you received: 4648
08 Jul 2012 00:06 #21686
Replied by andypugh on topic Re:Threadmilling problem
109jb wrote:
2.4 docs: www.linuxcnc.org/docs/2.4/html/gcode_main.html#sub:G2,-G3:-Arc
2.5 docs: www.linuxcnc.org/docs/2.5/html/gcode/gcode.html#sec:G2-G3-Arc
I strongly urge upgrading LinuxCNC (You don't need to update Ubuntu or anything else)
The only hassle is that the emc folder becomes linuxcnc, and you will need to change the paths to files in the INI file because of this.
wiki.linuxcnc.org/cgi-bin/wiki.pl?UpdatingTo2.5
Multi-turn arcs were a new feature in linuxCNC version 2.5.What am I doing wrong with the muti-turn helix? I am using LinuxCNC version 2.4.6.
- 109jb
08 Jul 2012 06:50 #21688
by 109jb
Replied by 109jb on topic Re:Threadmilling problem
Thank you. I will upgrade to 2.5. Should have known it was something simple.
- ArcEye
- Thank you received: 240
08 Jul 2012 14:36 #21692
by ArcEye
No need for editing etc. just carry on using the same stuff as before
Replied by ArcEye on topic Re:Threadmilling problem
All I did was create a symlink to ~/emc2 called ~/linuxcnc and thereafter ignored it.The only hassle is that the emc folder becomes linuxcnc, and you will need to change the paths to files in the INI file because of this.
Time to create page: 0.257 seconds
