probe m6
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
08 Oct 2012 20:51 #25141 by billykid
Replied by billykid on topic Re:probe m6
of course I installed 2.6 master by buildbot :-)
Now I have to fix python
thanks to all
Mauro
  • billykid
  • Platinum Member
  • Platinum Member
09 Oct 2012 20:56 #25184 by billykid
ok now LinuxCNC 2.6.0 running on my machine. configuration in sim / remap but will not start.
these are the errors:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.0-pre0-3252-g15cc8c8
Machine configuration directory is '/home/mauro/linuxcnc/configs/sim/remap/manual-toolchange-with-tool-length-switch'
Machine configuration file is 'manualtoolchange.ini'
INIFILE=/home/mauro/linuxcnc/configs/sim/remap/manual-toolchange-with-tool-length-switch/manualtoolchange.ini
PARAMETER_FILE=sim_mm.var
TASK=milltask
HALUI=halui
DISPLAY=axis
DISABLE_SERVER=
SERVER_PATH=
SERVER_ARGS=
SERVER_LOG=
Starting LinuxCNC...
Starting redis server program:
redis server started as: 'redis-server ', logging to: /dev/null
io started
halcmd loadusr io started
Killing task linuxcncsvr, PID=1471
Killing task redis-server, PID=1470
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
Can not find -sec REDIS -var DISABLE_SERVER -num 1
Can not find -sec REDIS -var SERVER_PATH -num 1
Can not find -sec REDIS -var SERVER_ARGS -num 1
Can not find -sec REDIS -var SERVER_LOG -num 1
Could not open command file '../../core_sim.hal'
1471
PID TTY STAT TIME COMMAND
1470
1470 ? Dl 0:00 redis-server
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 60.632212] I-pipe: Domain RTAI registered.
[ 60.632234] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 60.632242] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 60.632310] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 60.632318] PIPELINE layers:
[ 60.632326] f8605e20 9ac15d93 RTAI 200
[ 60.632333] c085cb20 0 Linux 100
[ 60.687567] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 60.688653] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 60.688671] RTAI[sched]: hard timer type/freq = APIC/8312900(Hz); default timing: periodic; linear timed lists.
[ 60.688682] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596014000 hz.
[ 60.688691] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 60.688844] RTAI[usi]: enabled.
[ 60.817884] RTAI[math]: loaded.
[ 62.302714] RTAI[math]: unloaded.
[ 62.385350] SCHED releases registered named ALIEN RTGLBH
[ 62.416470] RTAI[malloc]: unloaded.
[ 62.516054] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 62.521926] I-pipe: Domain RTAI unregistered.
[ 62.522008] RTAI[hal]: unmounted.
thanks
Mauro
14 Oct 2012 15:42 #25304 by mhaberler
Replied by mhaberler on topic Re:probe m6
Hi Mauro,
please report:
- how exactly did you install LinuxCNC
- exactly which commands did you execute before the error appeared
- Michael
  • billykid
  • Platinum Member
  • Platinum Member
14 Oct 2012 17:13 #25306 by billykid
Hi Michael.
i have installed linuxcnc from latest Ubuntu cd with linuxcnc 2.5.0 in a clean disk.
upgraded to 2.5.1
software sources = buildbot.linuxcnc.org/ lucid master-rt
upgraded to 2.6.0 master copy my machine config into home/linuxcnc.
the cnc run properly...
if i open: sample config/sim/remap/remap with tool probe ........ emc do not start and give these error.
my hardware: intel 945 cpu atom 230 2gb ram
Mesa 7i43-u-4 parallel card
I hope to have written everything you need
thanks
Mauro
14 Oct 2012 19:16 #25310 by mhaberler
likely something is wrong with your installation - can you run any other configuration?
I suggest to remove the 2.5.* installations and then install only the 2.6.0
- Michael
  • billykid
  • Platinum Member
  • Platinum Member
14 Oct 2012 20:04 #25314 by billykid
It other configurations sim / axis depart regularly.
with my configuration of 2.5.1 can work perfectly with the 2.6.0pre.
I will try to install 2.6 directly without 2.5 but I'm not very experienced ..
thanks
Mauro
