Does anyone know if the rotate part of G10L2 work?
- digimetal
10 Apr 2010 14:54 #2566
by digimetal
Does anyone know if the rotate part of G10L2 work? was created by digimetal
I am have bother rotating a program using G10L2 - the offset works but the rotate does not.
It's listed in the documentation as :
G10 L2 P[coordinate system] R[rotation about Z] axes...
www.linuxcnc.org/docs/devel/html/gcode_m...:G10:-Set-Coordinate
but for the life of me I can not make the bugger rotate.
Any thoughts or comments would be much appreciated.
All the Best
Simon
All the Best
Simon
- BigJohnT
- Thank you received: 994
11 Apr 2010 06:31 #2576
by BigJohnT
Replied by BigJohnT on topic Re:Does anyone know if the rotate part of G10L2 work?
Are you using this on an actual machine or just looking at the backplot in Axis?
- digimetal
12 Apr 2010 08:08 #2597
by digimetal
Replied by digimetal on topic Re:Does anyone know if the rotate part of G10L2 work?
Hi John,
Looking at the plot on Axis (2.3) shows translation but no rotation.
If I run the machine like that it will all get a bit costly!
It's a retro fitted Beaver mill (Bridgeport size) with some beefy motors.
I've been lurking (dreaming) for a while but it's been built and running a year now.
Si
Si
Time to create page: 0.745 seconds
