probing - false triggers during g1 and g0 moves
13 years 11 months ago #27004 by jslindsay
I am using a home made probe to do cutter length correction after manual tool changes. If I leave the probe hooked up, the acceleration during machining will sometimes trigger the probe and stop a non probing
( g0,g1,g3 etc.) G code. I had assumed the probe was only active during the G38 straight probe motion but that is obviously not the case. Is there a way to turn off the probe input without resorting to unplugging it each time it is used?
13 years 11 months ago #27005 by ArcEye
Hi
You should be able to unlink whatever you have linked to motion.probe-input and re-connect when required, using a M Code script
See
linuxcnc.org/docs/2.5/html/hal/basic_hal.html#_unlinkp
and
linuxcnc.org/docs/2.5/html/gcode/m-code....d_sec_m100_to_m199_a
13 years 11 months ago #27007 by BigJohnT
Or block the input with a switch...
The following user(s) said Thank You: jslindsay
13 years 11 months ago - 13 years 11 months ago #27008 by PCW
Which leads to possibly using the 'and' component and a gcode settable bit (say using M62, M63)
to mask the probe input in the gcode when you dont want it to be enabled.
Last edit: 13 years 11 months ago by PCW.
13 years 11 months ago #27022 by jslindsay
thanks for the suggestions. I have investigated modifing the hal.ini file to include anding a setable variable. I like simple solutions and adding a toggle switch as John has suggested will work until I get ambitious.
thanks
13 years 11 months ago #27023 by jslindsay
maybe I should just make a better probe grin
Time to create page: 0.261 seconds
