G33.1 taping
13 years 9 months ago #28945 by tld70
G33.1 taping was created by tld70
Hi Guys
I have wrot a small testprogramm where I want to check some functions on my machine.
When the machine arrives at G33.1 the Z axis will go down and do tapping,
when the Z Axis is down and the spindle will revers then the Z- Axis will move up in rapid feet.
when the programm do the 2. cycle it will be OK
What is wron in this Program
Attached is the Programm
Thomas
(Testprogramm )
g10 l2 p1 x0 y0 z0 ( G54 laden )
g10 l2 p2 x-200 y-50 z-100 ( G55 laden )
g10 l2 p3 x0 y0 z0 ( G56 laden )
g10 l2 p4 x0 y0 z0 ( G57 laden )
g10 l1 p1 z50 r5 ( WZK T1 laden 50 radius 5)
g10 l1 p2 z50 r1 ( WZK T2 laden 50 radius 1)
g10 l1 p3 z50 r5 ( WZK T3 laden 50 radius 5)
g10 l1 p4 z50 r5 ( WZK T4 laden 50 radius 5)
g10 l1 p5 z50 r5 ( WZK T5 laden 50 radius 5)
g10 l1 p6 z50 r5 ( WZK T6 laden 50 radius 5)
g10 l1 p7 z50 r5 ( WZK T7 laden 50 radius 5)
g10 l1 p8 z50 r5 ( WZK T8 laden 50 radius 5)
g10 l1 p9 z50 r5 ( WZK T9 laden 50 radius 5)
g10 l1 p10 z50 r5 ( WZK T10 laden 50 radius 5)
g10 l1 p11 z123 r5 ( WZK T11 laden 123 radius 5)
g10 l1 p12 z50 r0 ( WZK T12 laden 50 radius 0)
#1=0 ( Variable auf 0 setzen )
o100 do
G0 G17 G21 G40 G49 G54 G64 G80 G90 G94 X0 Y0 Z0
G0 G90 G55 x0 y0 z0
t2 m6 G43 h2
S500 m3
G0 G90 X-50 Y-100 Z-150 (Im Eilganz zur Startposition)
(Loch bohren)
G91 G98 F1000
G81 Y-5 R-1 Z-50 L7 ( beschreibung )
y-5
y-5
y-5
y-5
G80
g90
g0 Z0
T12 M6 G43 H12
S500m3
G0 G90 X-50 Y-105 Z-150 (Im Eilganz zur Startposition)
(Gewinde)
G91
G33.1 Z-20 K0.01 ( 20mm tiefen 0.01 mm steigung )
G0 G90
y0 z0
t7m6 G43 h7
z-200
t12m6 G43 h12
z0
x0
t2m6 G43 h2
y-100
(print,value of variable 123 is: #1)
#1 = [#1 + 1]
o100 while [#1 LT 99]
M30
13 years 9 months ago #28992 by andypugh
Replied by andypugh on topic G33.1 taping
tld70 wrote: when the Z Axis is down and the spindle will revers then the Z- Axis will move up in rapid feet.
Are you saying that the tool spirals down as expected, but then backs out at the rapid rate when the spindle reverses?
If so, then I don't think that is a G-code problem but a machine problem. Does the encoder count correctly in both directions?
13 years 9 months ago #29006 by tld70
Replied by tld70 on topic G33.1 taping
Hi andypugh
yes when the Spindle will revers, then the Z- Axis muve up in highspeed ( as fast as the Axis can )
And the encoder counts, I see the speed in the display in bouth directions.
When the Programm repead the 2. time the tapping will work.
Is the Program OK?
13 years 9 months ago #29015 by andypugh
tld70 wrote: the encoder counts, I see the speed in the display in bouth directions.
Can you check that spindle-pos counts up in one direction and down in the other (probably just by turning the spindle by hand)
Is the Program OK?
It looks OK, though tapping in incremental (G91) mode seems a little unusual.
Can you run a test in air with the G33.1 running in G90 mode?
G91 ought to be OK, but perhaps you found a bug?
13 years 9 months ago #29140 by tld70
Hello andypugh
I installed the 2.6 version to check if the problem is gone.
Now the machine moves to the position where I want to tap.
The Machine only stops.
I dont know why.
you see on the picture the Speed from Spindle and the Z-Acis want to go 130mm in plus? Why?
The tappinghole goes to minus direction.
Where can I look why the Program stopps?
13 years 9 months ago #29146 by andypugh
tld70 wrote: I installed the 2.6 version to check if the problem is gone.
I dont know why.
Is it possible that it is waiting for an index that isn't happening?
Time to create page: 0.061 seconds
