G33.1 taping
13 years 9 months ago #29162 by tld70
Replied by tld70 on topic G33.1 taping
the index is OK.
I Try setp hm2_5i20.1.encoder.00.index-enable 1
after 1 turn this signal switch 0
I try this some times and it work.
13 years 9 months ago #29163 by tld70
i mean the signal works, not the tapping
13 years 9 months ago #29186 by tld70
I did removed follow hal line after go ti version 2.6
net spindle-revs <= hm2_5i20.1.encoder.00.position motion.spindle-revs
now I did this line into my hal ant have now the same problem Z- Axis goes down, and when the spindle will revers the Z- Axis move wirt high speed up
13 years 9 months ago - 13 years 9 months ago #29187 by andypugh
Replied by andypugh on topic G33.1 taping
tld70 wrote: I did removed follow hal line after go ti version 2.6
It is hard to diagnose the problem when you make changes like that and don't mention them.
Is it possible to get a halscope plot of motion.spindle-revs and Z position during the cycle?
Last edit: 13 years 9 months ago by andypugh.
The following user(s) said Thank You: tld70
13 years 9 months ago #29188 by tld70
Hi andypugh
when I saw the motion.spindle-revs you wrote i looked in the forum
i found somethind, and add follow to my hal:
net spindle-deg <= hm2_5i20.1.encoder.00.position
setp scale.0.gain 0.01667
net spindle-deg => scale.0.in
net spindle-revs scale.0.out motion.spindle-revs
I didnt know I have to convert something
Hope this is ok.
Now the tapping works ( without tool )
Thank you
13 years 9 months ago #29189 by andypugh
tld70 wrote: net spindle-deg <= hm2_5i20.1.encoder.00.position
That shouldn't be necessary.
hm2_5i20.1.encoder.00.position should count spindle revolutions. One turn of the spindle should increase it by exactly 1.
The place to set that scaling is the hm2_5i20.1.encoder.00.scale parameter, not with an external scale component.
Time to create page: 0.107 seconds
