g-code replacement filter?
04 Mar 2013 22:53 #30847 by andypugh
Replied by andypugh on topic g-code replacement filter?
Great, so how do i tell LinuxCNC to use this filter program? Will it just know?
You need to add an entry in the correct part of the INI file:
www.linuxcnc.org/docs/html/config/ini_co...sub_filter_section_a
05 Mar 2013 20:24 #30912 by tjamscad
Replied by tjamscad on topic g-code replacement filter?
How do I tell it to be called up? This is what is in the .ini now
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
So, I write this program and name it convert.py. Where do I put it in the file tree and how do i list it in the .ini section?
05 Mar 2013 20:51 #30913 by andypugh
[FILTER]
py = python?
Looking at image-to-gcode as an example: Put your new filter program (which would need to be some sort of executable file) in the same place as image-to-gcode, which lives in /usr/bin/ with most other executable programs. Lets assume that the file is called gcodefilter andyou want to leave .ngc files unfiltered, and convert .tap files
PROGRAM_EXTENSION = .tap Some Comment Here if You Want
then you need to tell the system which filter to use:
.tap = gcodefilter
And that should be it.
05 Mar 2013 21:16 #30916 by tjamscad
Thanks, Andy
I am sure I will be asking more later but for now.
My new .ini
[FILTER]
PROGRAM_EXTENSION = .ngc gcode file
PROGRAM_EXTENSION = .txt possible gcode file
py = python
ngc = gcodeconvert.txt
txt = gcodeconvert.txt
and filter just for testing "y0" is changed to "stop"
#!/bin/bash
sed -e 's/\(y0\)\([0-1000000]*\)/stop\2/' $1
05 Mar 2013 21:25 #30918 by andypugh
Having a .txt extension on an executable file is a little bit unusual.
06 Mar 2013 05:51 #30942 by tjamscad
That is true, I just told Ubuntu to make it executable. Should it be something else?
06 Mar 2013 06:09 #30943 by andypugh
Linux doesn't really care. It just looks funny.
22 Mar 2013 06:18 - 22 Mar 2013 06:21 #31701 by tjamscad
I have broken my filter. Where should the exe be located? will this be ok in the ini? My previous attempt was working now it is not and changeing back to what it was didnt help either.
[FILTER]
py = python
ngc = convert.py
txt = convert.py
Last edit: 22 Mar 2013 06:21 by tjamscad.
Time to create page: 0.124 seconds
