rotational offset to jog keys
- strykerg
27 Mar 2013 23:24 #31984
by strykerg
rotational offset to jog keys was created by strykerg
i use my lathe a lot in manual mode by using the keyboards arrow keys. is it possible to create a rotational offset so that when i move forward in x the lathe feeds in at an angle? something similar to g10 l2?
- Thank you received: 4663
28 Mar 2013 15:12 #31994
Replied by andypugh on topic rotational offset to jog keys
I don't think it is. The G10 rotation is about the Z axis.
You might find something like my semi-manual lathe to be more convenient:
www.bodgesoc.org/lathe/lathe.html
Though I need to update the subroutines posted there, as they don't take any notice of the "angle" spinbox, which is what you need.
One advantage of this over manual jogging is that is can automatically do multiple passes, so you can walk away and do something else.
A typical sequence of events for me:
home
T1 button (load Tool 1)
jog to just short of the end of the work.
Touch off to +0.5mm
set target Z to 0, target X to -1
press the "Facing" button.
Set target Z to -20 (for example). Set target X to 1mm more than desired diamter.
press "Turning". It will take as many passes as needed, The final X move is to programmed dia
When it finishes, measure the actual diameter. Touch off X to the measurement.
Set the actual desired diameter in the box
press "Turning" again.
With my current subroutines both boring and turning follow the "angle" box.
"Radius" is only used by the turning sub (for a run-out) and the radius button.
Most routines start from the jogged-to position and end at the X and Y from the spinboxes. Radius and chamfer don't, they start from the (X.Y) corner of the work.
Threading starts from current Z, but starts threading at spinbox X, then finishes at the spinbox depth.
For most things I make I don't write G-code, I just create the part step-by-step like you would by hand, except I don't need to stand there twiddling knobs.
home
Touch off to +0.5mm
The following user(s) said Thank You: strykerg
- strykerg
28 Mar 2013 16:34 #31997
by strykerg
Replied by strykerg on topic rotational offset to jog keys
that's a pretty neat setup you have there I will definitely put that in my ui straight away
I hope I manage to set it up. the few gui buttons I made were done with glade
what I actually wanted to do is turn a pulley but not plunging with a tool shaped like the pulley... something like this: www.green-trust.org/junkyardprojects/Fre...ingV-BeltPulleys.pdf
I could always put my lazy arse on the pc and write some code for the pulley
but I really like your setup thanks for that it will definitely make my life easier
- BigJohnT
- Thank you received: 994
29 Mar 2013 01:36 #32013
by BigJohnT
Replied by BigJohnT on topic rotational offset to jog keys
If you had a MPG you could set the scale of X and Z jog and get any angle you want...
- Rick G
- Thank you received: 114
29 Mar 2013 11:03 #32026
by Rick G
You might want to look at ngcgui.
There are samples of subs for the lathe including ID taper and OD taper, just punch a few numbers and or an angle, set the depth of cut per pass and let the computer do the work.
Rick G
Replied by Rick G on topic rotational offset to jog keys
That might come in handy, but I only use jogging to set a touch off position.i move forward in x the lathe feeds in at an angle? something similar to g10 l2?
Rick G
- BigJohnT
29 Mar 2013 13:32 - 29 Mar 2013 13:33 #32035
by BigJohnT
Like Rick said ngcgui and some subs and I do 95% of my ops like that on my lathe.
I have most of my subs on my web site.
gnipsel.com/shop/hardinge/hardinge.xhtml
Last edit: 29 Mar 2013 13:33 by BigJohnT.
- strykerg
29 Mar 2013 14:26 #32039
by strykerg
i do have an mpg. could you explain how to do this?
i installed Andy's subs and they work great. John the ones you linked also look very useful i will try and find some time to try them
- BigJohnT
29 Mar 2013 14:54 #32041
by BigJohnT
Basically you enable both axis jogs to cut at say 45 degree angle the scale for each axis would be the same.
Take a look at the MPG example in the manual:
linuxcnc.org/docs/html/examples/mpg.html
See the part where the switch enables each axis if you added some and's and used the third position to enable both you would have a 45 cut.
29 Mar 2013 15:45 #32042
ngcgui is in many ways a better solution than my way. You get a preview and can string a bunch of things together to make a complete program.
I have updated the ngc files at www.bodgesoc.org/lathe/lathe.html so that turning now takes note of the angle request.
- strykerg
30 Mar 2013 07:22 #32088
by strykerg
thanks to both of you this is some seriously useful info you gave me. now i just need to put everything together.
do you think that if i rewrite the ui with glade it would solve the problem where spinboxes value is not registered when manually entered? (as you mentioned its annoying having to press up and down after entering a value)
Time to create page: 0.123 seconds
