Subroutine that change the tool diameter.
- grandixximo
- Thank you received: 413
07 Apr 2013 06:36 - 07 Apr 2013 06:42 #32366
by grandixximo
Subroutine that change the tool diameter. was created by grandixximo
i made this g code, and i have some disagreement with how the interpreter execute it...
at the end of this gcode the diameter of my tool in my opinion should be smaller of 11 units, actually it only removed one units, because the parameter #5400 did not change when i changed the tool diameter with the G10 L1 , this happens also with G10 L10.
This is a minor issue i can write #800 to be 11 the second time, but still if there was an O-code to update the read only parameters it would be nice.
Another disagreement is if i add G42 movement between one diameter change and the other like here.
here comes the funny part, the graphical preview shows me two different trajectory when i load this, but when i play it, it goes twice on the same trajectory as if the diameter didn't change, this happens with both G10 L1 and G10 L10.
if i add a tool change in the middle just after calling the subroutine, the preview will show a single line, but when i play it i got two lines, and also the diameter will be changed 11 units instead of only one.
So placing a tool change in middle of this g code fixes it, but it's really time wasting since normally i have my spindle running at high speed and i have to stop it and run it again for the tool change to happen.
Any thoughts on why this happen exactly and is there a better solution to refresh tools, other than tool changing?
o111 sub
G10 L1 P[#5400] R[#5410/2-#800/2]
o111 endsub
T1M6
#800 = 10
o111 call
#800 = 1
o111 call
t0m6
M2at the end of this gcode the diameter of my tool in my opinion should be smaller of 11 units, actually it only removed one units, because the parameter #5400 did not change when i changed the tool diameter with the G10 L1 , this happens also with G10 L10.
o111 sub
G10 L10 P[#5400] R[#5410/2-#800/2]
o111 endsub
G40
T1M6
G0 X100 Y100
G42 X200 Y200
G1X300 Y200 F2000
G40
#800 = 10
o111 call
G0 X100 Y100
G42 X200 Y200
G1X300 Y200 F2000
G40
#800 = 1
o111 call
T0M6
M2here comes the funny part, the graphical preview shows me two different trajectory when i load this, but when i play it, it goes twice on the same trajectory as if the diameter didn't change, this happens with both G10 L1 and G10 L10.
Last edit: 07 Apr 2013 06:42 by grandixximo.
- grandixximo
07 Apr 2013 15:03 - 08 Apr 2013 04:30 #32382
by grandixximo
Replied by grandixximo on topic Subroutine that change the tool diameter.
sorry, i updated from 2.5.0 to 2.5.2 and it's working now, you can close this
I did have some changes in my 2.5.0, but i re downloaded the source and it presents the same problem, so this was indeed fixed from 2.5.0 to 2.5.2
Last edit: 08 Apr 2013 04:30 by grandixximo.
Time to create page: 0.135 seconds
