Display Error when loading this file?
13 Aug 2013 21:25 #37637 by U2fletch
Display Error when loading this file? was created by U2fletch
Been working with several files making some plywood parts. Attempted to load this file and the display gets about 3/4 of the way through drawing the first hole. Cannot run program code. No errors from LinuxCNC.
Went to different computer, booted up in sim mode, tried to load the file and got same results! It is not just my work machine having the problem.
Any ideas what is causing LinuxCNC to choke on this file?
It was created with CamBAM, and I have used this code before today, but for some reason it won't load now.
13 Aug 2013 23:38 #37640 by U2fletch
Replied by U2fletch on topic Display Error when loading this file?
My Bad,
Just looked closely at what I thought was a display issue. What was displayed was a HUGE arc. The rest of my file was in there, but was incredibly tiny.
Looked at last line of G-Code and found an error produced by CamBAM. Took that out and all is good.
Whew!
Time to create page: 0.145 seconds
