Vectric Cut2D
  • probamo
  • probamo's Avatar Topic Author
  • Premium Member
  • Premium Member
15 Aug 2013 15:46 #37686 by probamo
Vectric Cut2D was created by probamo
Hello everyone,
reading through the topics and looking for a tool-path software that can generate GCode for CNC machine running under LinuxCNC, I found not that much still running under Linux. However, lots of good impressions users are talking about Vectric Cut2D application. Furthermore, you can open there dxf, eps files generated by QCad or inkscape like software, choose the appropriate tool, and set the tool-path. Having finished all, I am not quite sure which GCode format shall I save to run in LinuxCNC controller (.txt, .cnc, .tap) because there is no possibility to save generated Code in .ngc.
Any advise.
Thank you!
15 Aug 2013 16:42 #37688 by cncbasher
Replied by cncbasher on topic Vectric Cut2D
the filename prefix can be set in your ini file to NGC TAP or whatever you wish it is only a text file
so long as in cut2d you use the ( linuxcnc or emc) postprocessor it will work fine ..
the post processor can be made to output any prefix filename
if you do not have a postprocessor for linuxcnc in your cut2d , their is one on the wiki page already set up
  • probamo
  • Premium Member
  • Premium Member
15 Aug 2013 17:22 #37692 by probamo
Replied by probamo on topic Vectric Cut2D
Here is what I've just found.
Cut2D
Cut3D
Is there any experienced to test it and let us know if this works fine?
Thank you.
15 Aug 2013 17:32 #37697 by cncbasher
wiki.linuxcnc.org/cgi-bin/wiki.pl?Cam_Post
I have no reason to believe their is anything wrong with the postprocessors on vectric forum .
postprocessors can be modified to suit individual needs and requirements .
I certainly have not had any problems, and not had any feedback as to any problems with the postprocessors I posted
The following user(s) said Thank You: probamo
  • probamo
  • Premium Member
  • Premium Member
15 Aug 2013 19:40 #37713 by probamo
@cncbasher
Thank You.
Time to create page: 0.289 seconds
