Here is a bit of my dodgy work.
13 Sep 2013 14:21 - 13 Sep 2013 14:32 #38752 by JZHA1985
Here is a bit of my dodgy work. was created by JZHA1985
Dodgy since I don't code much and so forth.
Plus I have a little Microcarve A4 machine (that is very hard to break even from my moronic mistakes I have made over the years)
and I just make a few dollars on the side.
I always do 3d profiling with high tolerances, and never have done any 2d stuff for money.
Anyways it's crude , kinda ugly, and not organized (I probably don't use Linux CNC the right way in several ways).
I have made 65 of them and need to make a few more, and get them finished this Tuesday.
But anyways here is the skeleton of the procedural code for your amusement..
It makes copies of whatever you want, has an area for code that it uses to cut things out in multible passest, and it works.
With some humor, am I completely coding things in an obfuscated fashion?
And also, check out OPENSCAM as it works rather well now, and meshes well with LinuxCNC. (and yes it even works with this mess)
( by Scorch - 2012 )
(Settings used in f-engrave when this file was created)
(fengrave_set show_axis  1 )
(fengrave_set show_box   1 )
(fengrave_set show_thick 1 )
(fengrave_set flip       0 )
(fengrave_set mirror     0 )
(fengrave_set outer      1 )
(fengrave_set upper      1 )
(fengrave_set v_flop     1 )
(fengrave_set v_pplot    1 )
(fengrave_set bmp_long   1 )
(fengrave_set YSCALE     2.0 )
(fengrave_set XSCALE     100 )
(fengrave_set LSPACE     1.1 )
(fengrave_set CSPACE     25 )
(fengrave_set WSPACE     100 )
(fengrave_set TANGLE     0.0 )
(fengrave_set TRADIUS    0.0 )
(fengrave_set ZSAFE      0.1 )
(fengrave_set ZCUT       -0.005 )
(fengrave_set STHICK     0.01 )
(fengrave_set origin     Bot-Left )
(fengrave_set justify    Left )
(fengrave_set units      in )
(fengrave_set xorigin    0.0 )
(fengrave_set yorigin    0.0 )
(fengrave_set segarc     10.0 )
(fengrave_set accuracy   0.001 )
(fengrave_set FEED       45 )
(fengrave_set fontfile   "AIRSTREA.TTF" )
(fengrave_set H_CALC     max_use )
(fengrave_set plotbox    box )
(fengrave_set boxgap     0.25 )
(fengrave_set cut_type    v-carve )
(fengrave_set v_bit_angle 60 )
(fengrave_set v_bit_dia   0.125 )
(fengrave_set v_drv_crner 135 )
(fengrave_set v_stp_crner 200 )
(fengrave_set v_step_len  0.01 )
(fengrave_set v_check_all all )
(fengrave_set bmp_turnp   minority )
(fengrave_set bmp_turds   2 )
(fengrave_set bmp_alpha   1 )
(fengrave_set bmp_optto   0.2 )
(fengrave_set fontdir    "fonts" )
(fengrave_set gpre         G17 G90 G64 M3 S3000 M7 )
(fengrave_set gpost        M5 M9 M2 )
(fengrave_set imagefile   "C:/Users/I5/Desktop/grown/big_island_grown.bmp" )
(fengrave_set input_type  image )
(fengrave_set clean_dia   .25 )
(fengrave_set clean_step  50 )
(fengrave_set clean_w     2 )
(fengrave_set clean_v     0.05 )
(fengrave_set clean_paths  1,1,0,0,1,0 )
(fengrave_set TCODE    010 )
( Fontfile: AIRSTREA.TTF )
#1 = 0.02000  ( Safe Z )
#2 = -0.040  ( Engraving Depth Z )
#3 = 0        (dynamic X offset variable)
#4 = 2.55       (size of piece/offset per piece cut. Only works for Square pieces)
#5 = 4         (NUMBER of X Copies)
#6 = 3     (number of passes for cut out)
#7 = 0       (Z Cut level variable)
#8 = .1    (DOC per pass)
#9 = 0       (Y Offset Variable)
#10 = 2      (NUMBER of y Copies )
G10 L2 P1 X0 Y0 Z0 (offsets nuked)
g10 L2 P2 X0 Y0 Z0
t1m6 (60degree .125" cutter)
G20
F40.00  ( Set Feed Rate )
o107 repeat   [#10] (Y Offset)
  o103 repeat [#5] (engraving a few things with X offset)
G10 L2 P2 X#3 Y#9 (enacted offsets)
G55            (a g55 offset)
(Code)
G0 Z#1
G0 X0.3668 Y1.1870
G1 Z-0.0000
G3 X0.3736 Y1.1960 R0.0257 Z-0.0142
G1 X0.3779 Y1.2025 Z-0.0226
G1 X0.3747 Y1.2158 Z-0.0172
G1 X0.3648 Y1.2257 Z-0.0000
G1 X0.3750 Y1.2155 Z-0.0177
G1 X0.3852 Y1.2090 Z-0.0291
G2 X0.4161 Y1.2122 R0.2555 Z-0.0240
G1 X0.4364 Y1.2135 Z-0.0229
G1 X0.4781 Y1.2159 Z-0.0236
G1 X0.5315 Y1.2202 Z-0.0283
G1 X0.5436 Y1.2220 Z-0.0309
G1 X0.5500 Y1.2292 Z-0.0230
G1 X0.5568 Y1.2395 Z-0.0091
G0 Z#1
G0 X0.5615 Y1.2430
G1 Z-0.0000
G1 X0.5567 Y1.2393 Z-0.0093
G1 X0.5486 Y1.2270 Z-0.0256
G0 Z#1
G0 X0.5635 Y1.2238
G1 Z-0.0000
G1 X0.5537 Y1.2143 Z-0.0170
G1 X0.5635 Y1.2048 Z-0.0000
G1 X0.5523 Y1.2156 Z-0.0194
G1 X0.5412 Y1.2216 Z-0.0302
G1 X0.4978 Y1.2173 Z-0.0248
G1 X0.4623 Y1.2150 Z-0.0230
G3 X0.4125 Y1.2120 R5.1473 Z-0.0243
G1 X0.3817 Y1.2079 Z-0.0294
G1 X0.3763 Y1.2002 Z-0.0197
G1 X0.3685 Y1.1879 Z-0.0032
G0 Z#1
G0 X0.4898 Y1.2746
G1 Z-0.0000
G1 X0.4974 Y1.2772 Z-0.0124
G1 X0.5079 Y1.2856 Z-0.0271
G1 X0.5017 Y1.2970 Z-0.0108
G1 X0.5057 Y1.2904 Z-0.0215
G1 X0.5136 Y1.2862 Z-0.0275
G1 X0.5218 Y1.2871 Z-0.0259
G1 X0.5297 Y1.2894 Z-0.0244
G1 X0.5361 Y1.2925 Z-0.0229
G1 X0.5410 Y1.2959 Z-0.0218
G1 X0.5453 Y1.3000 Z-0.0207
G1 X0.5488 Y1.3046 Z-0.0198
G3 X0.5538 Y1.3149 R0.0484 Z-0.0188
G3 X0.5560 Y1.3260 R0.0529 Z-0.0193
G3 X0.5553 Y1.3374 R0.0469 Z-0.0210
G1 X0.5540 Y1.3431 Z-0.0221
G1 X0.5519 Y1.3486 Z-0.0234
G1 X0.5492 Y1.3538 Z-0.0246
G1 X0.5459 Y1.3584 Z-0.0258
G1 X0.5420 Y1.3625 Z-0.0269
G1 X0.5375 Y1.3661 Z-0.0277
G1 X0.5270 Y1.3707 Z-0.0282
G1 X0.5156 Y1.3725 Z-0.0282
G1 X0.5099 Y1.3718 Z-0.0274
G1 X0.4992 Y1.3677 Z-0.0246
G1 X0.4873 Y1.3575 Z-0.0210
G3 X0.4757 Y1.3414 R0.1742 Z-0.0195
G2 X0.4586 Y1.3148 R1.5493 Z-0.0205
G2 X0.4442 Y1.2991 R0.0657 Z-0.0264
G1 X0.4354 Y1.2943 Z-0.0289
G1 X0.4215 Y1.2928 Z-0.0295
G2 X0.4086 Y1.2959 R0.0526 Z-0.0284
G2 X0.3950 Y1.3033 R0.0560 Z-0.0283
G1 X0.3865 Y1.3116 Z-0.0281
G1 X0.3841 Y1.3156 Z-0.0272
G1 X0.3816 Y1.3211 Z-0.0260
G1 X0.3797 Y1.3280 Z-0.0244
G1 X0.3787 Y1.3362 Z-0.0229
G2 X0.3808 Y1.3522 R0.0440 Z-0.0219
G1 X0.3830 Y1.3577 Z-0.0224
G1 X0.3871 Y1.3639 Z-0.0229
G2 X0.3952 Y1.3708 R0.0380 Z-0.0241
G1 X0.4112 Y1.3783 Z-0.0267
G1 X0.4275 Y1.3813 Z-0.0280
G1 X0.4339 Y1.3874 Z-0.0176
G0 Z#1
G0 X0.4423 Y1.3954
G1 Z-0.0000
G1 X0.4380 Y1.3918 Z-0.0097
G1 X0.4373 Y1.3908 Z-0.0114
G1 X0.4315 Y1.3851 Z-0.0218
G0 Z#1
G0 X0.4443 Y1.3798
G1 Z-0.0000
G1 X0.4341 Y1.3744 Z-0.0174
G1 X0.4397 Y1.3671 Z-0.0064
G0 Z#1
G0 X0.4398 Y1.3633
G1 Z-0.0000
G1 X0.4388 Y1.3687 Z-0.0090
G1 X0.4296 Y1.3796 Z-0.0253
G1 X0.4245 Y1.3812 Z-0.0279
G1 X0.4108 Y1.3782 Z-0.0266
G1 X0.3974 Y1.3721 Z-0.0246
G1 X0.3884 Y1.3653 Z-0.0231
G1 X0.3852 Y1.3614 Z-0.0227
G1 X0.3825 Y1.3568 Z-0.0223
G3 X0.3793 Y1.3460 R0.0472 Z-0.0219
G3 X0.3788 Y1.3339 R0.0410 Z-0.0233
G1 X0.3800 Y1.3265 Z-0.0248
G1 X0.3824 Y1.3191 Z-0.0265
G1 X0.3861 Y1.3122 Z-0.0280
G1 X0.3914 Y1.3062 Z-0.0286
G3 X0.4048 Y1.2975 R0.0568 Z-0.0285
G3 X0.4203 Y1.2929 R0.0545 Z-0.0294
G1 X0.4274 Y1.2927 Z-0.0296
G1 X0.4333 Y1.2937 Z-0.0292
G1 X0.4389 Y1.2956 Z-0.0284
G1 X0.4483 Y1.3026 Z-0.0246
G3 X0.4568 Y1.3125 R0.0708 Z-0.0211
G3 X0.4710 Y1.3342 R0.2167 Z-0.0192
G2 X0.4894 Y1.3598 R0.1797 Z-0.0213
G1 X0.4963 Y1.3658 Z-0.0236
G1 X0.5055 Y1.3706 Z-0.0263
G1 X0.5172 Y1.3724 Z-0.0282
G1 X0.5317 Y1.3690 Z-0.0280
G1 X0.5396 Y1.3646 Z-0.0273
G1 X0.5462 Y1.3581 Z-0.0257
G1 X0.5493 Y1.3535 Z-0.0245
G1 X0.5520 Y1.3485 Z-0.0234
G1 X0.5541 Y1.3429 Z-0.0221
G1 X0.5555 Y1.3365 Z-0.0208
G1 X0.5561 Y1.3300 Z-0.0198
G2 X0.5525 Y1.3116 R0.0469 Z-0.0188
G1 X0.5485 Y1.3042 Z-0.0199
G1 X0.5445 Y1.2992 Z-0.0209
G1 X0.5399 Y1.2950 Z-0.0220
G1 X0.5347 Y1.2917 Z-0.0232
G1 X0.5232 Y1.2874 Z-0.0257
G1 X0.5103 Y1.2862 Z-0.0279
G1 X0.5013 Y1.2805 Z-0.0182
G1 X0.4937 Y1.2745 Z-0.0068
G0 Z#1
G0 X0.5698 Y1.4081
G1 Z-0.0052
G1 X0.5690 Y1.4112 Z-0.0101
G1 X0.5647 Y1.4198 Z-0.0211
G1 X0.5498 Y1.4309 Z-0.0284
G2 X0.5142 Y1.4414 R2.6003 Z-0.0249
G1 X0.4586 Y1.4584 Z-0.0255
G1 X0.4138 Y1.4707 Z-0.0294
G1 X0.4054 Y1.4685 Z-0.0233
G1 X0.3927 Y1.4609 Z-0.0060
G0 Z#1
G0 X0.3892 Y1.4616
G1 Z-0.0000
G1 X0.4011 Y1.4659 Z-0.0176
G1 X0.4064 Y1.4797 Z-0.0187
G0 Z#1
G0 X0.4017 Y1.4906
G1 Z-0.0029
G1 X0.4022 Y1.4882 Z-0.0068
G1 X0.4095 Y1.4732 Z-0.0276
G1 X0.4313 Y1.4662 Z-0.0275
G2 X0.4843 Y1.4505 R1.3242 Z-0.0247
G1 X0.5330 Y1.4358 Z-0.0256
G1 X0.5485 Y1.4312 Z-0.0280
G1 X0.5564 Y1.4301 Z-0.0316
G0 Z#1
G0 X0.5550 Y1.4506
G1 Z-0.0000
G1 X0.5702 Y1.4490 Z-0.0247
G3 X0.5798 Y1.4753 R1.0046 Z-0.0224
G2 X0.5897 Y1.5026 R0.6368 Z-0.0239
G1 X0.5915 Y1.5146 Z-0.0201
G1 X0.5864 Y1.5240 Z-0.0061
G0 Z#1
G0 X0.5863 Y1.5277
G1 Z-0.0000
G1 X0.5886 Y1.5198 Z-0.0125
G1 X0.5938 Y1.5116 Z-0.0238
G0 Z#1
G0 X0.6113 Y1.5183
G1 Z-0.0000
G1 X0.6059 Y1.5166 Z-0.0076
G1 X0.5959 Y1.5126 Z-0.0210
G1 X0.5907 Y1.5053 Z-0.0242
G1 X0.5820 Y1.4815 Z-0.0225
G2 X0.5716 Y1.4528 R0.9238 Z-0.0240
G2 X0.5602 Y1.4304 R0.0632 Z-0.0334
G3 X0.5691 Y1.4110 R0.1876 Z-0.0099
G0 Z#1
G0 X0.5819 Y1.6037
G1 Z-0.0000
G1 X0.5909 Y1.5936 Z-0.0233
G3 X0.5958 Y1.6016 R0.2909 Z-0.0196
G3 X0.6058 Y1.6222 R0.7164 Z-0.0200
G0 Z#1
G0 X0.5959 Y1.6365
G1 Z-0.0000
G1 X0.6040 Y1.6481 Z-0.0245
G1 X0.5957 Y1.6514 Z-0.0221
G1 X0.5575 Y1.6612 Z-0.0207
G3 X0.5356 Y1.6667 R0.3024 Z-0.0224
G0 Z#1
G0 X0.5458 Y1.6769
G1 Z-0.0000
G1 X0.5497 Y1.6633 Z-0.0208
G1 X0.5886 Y1.6533 Z-0.0216
G1 X0.6095 Y1.6451 Z-0.0277
G2 X0.6422 Y1.6385 R0.1473 Z-0.0277
G1 X0.6531 Y1.6345 Z-0.0308
G1 X0.6672 Y1.6394 Z-0.0173
G1 X0.6716 Y1.6413 Z-0.0115
G0 Z#1
G0 X0.6786 Y1.6409
G1 Z-0.0000
G1 X0.6701 Y1.6407 Z-0.0135
G1 X0.6560 Y1.6342 Z-0.0303
G3 X0.6597 Y1.6168 R0.0645 Z-0.0095
G1 X0.6612 Y1.6119 Z-0.0029
G0 Z#1
G0 X0.6612 Y1.6101
G1 Z-0.0000
G1 X0.6605 Y1.6143 Z-0.0061
G1 X0.6563 Y1.6290 Z-0.0252
G1 X0.6474 Y1.6366 Z-0.0291
G1 X0.6328 Y1.6413 Z-0.0262
G1 X0.6237 Y1.6423 Z-0.0276
G1 X0.6151 Y1.6418 Z-0.0313
G1 X0.6127 Y1.6381 Z-0.0278
G2 X0.6098 Y1.6307 R0.1834 Z-0.0220
G2 X0.5985 Y1.6069 R0.8320 Z-0.0192
G2 X0.5900 Y1.5921 R0.1715 Z-0.0245
G1 X0.5864 Y1.5867 Z-0.0303
G1 X0.5867 Y1.5816 Z-0.0307
G3 X0.5912 Y1.5745 R0.0529 Z-0.0278
G1 X0.5964 Y1.5686 Z-0.0272
G1 X0.6065 Y1.5602 Z-0.0298
G1 X0.6156 Y1.5583 Z-0.0259
G1 X0.6238 Y1.5616 Z-0.0142
G1 X0.6222 Y1.5607 Z-0.0170
G1 X0.6128 Y1.5573 Z-0.0296
G3 X0.6160 Y1.5254 R0.2202 Z-0.0000
G1 X0.6122 Y1.5508 Z-0.0257
G1 X0.6068 Y1.5600 Z-0.0299
G2 X0.5914 Y1.5743 R0.0723 Z-0.0277
G1 X0.5858 Y1.5834 Z-0.0317
G2 X0.5592 Y1.6032 R0.1132 Z-0.0228
G2 X0.5342 Y1.6275 R1.0672 Z-0.0229
G2 X0.5099 Y1.6604 R0.1068 Z-0.0388
G1 X0.4906 Y1.6692 Z-0.0310
G1 X0.4763 Y1.6643 Z-0.0121
G0 Z#1
G0 X0.4685 Y1.6614
G1 Z-0.0000
G1 X0.4719 Y1.6621 Z-0.0056
G1 X0.4804 Y1.6659 Z-0.0175
G1 X0.4901 Y1.6690 Z-0.0304
G1 X0.4932 Y1.6857 Z-0.0206
G1 X0.4889 Y1.7019 Z-0.0000
G1 X0.4969 Y1.6725 Z-0.0376
G1 X0.5066 Y1.6654 Z-0.0420
G2 X0.5358 Y1.6667 R0.0777 Z-0.0223
G0 Z#1
G0 X0.5312 Y1.6525
G1 Z-0.0000
G1 X0.5214 Y1.6410 Z-0.0254
G3 X0.5380 Y1.6238 R0.3303 Z-0.0226
G0 Z#1
G0 X0.5522 Y1.6277
G1 Z-0.0000
G1 X0.5484 Y1.6135 Z-0.0222
G1 X0.5672 Y1.5959 Z-0.0238
G0 Z#1
G0 X0.7130 Y1.6876
G1 Z-0.0000
G1 X0.7079 Y1.6885 Z-0.0078
G1 X0.6934 Y1.6863 Z-0.0239
G1 X0.6875 Y1.6748 Z-0.0165
G1 X0.6876 Y1.6617 Z-0.0000
G1 X0.6875 Y1.6763 Z-0.0185
G1 X0.6843 Y1.6876 Z-0.0291
G1 X0.6604 Y1.7062 Z-0.0246
G1 X0.6277 Y1.7340 Z-0.0223
G1 X0.5999 Y1.7575 Z-0.0220
G1 X0.5837 Y1.7746 Z-0.0272
G1 X0.5788 Y1.7852 Z-0.0366
G1 X0.5645 Y1.7875 Z-0.0246
G1 X0.5548 Y1.7846 Z-0.0133
G1 X0.5512 Y1.7825 Z-0.0087
G0 Z#1
G0 X0.5467 Y1.7798
G1 Z-0.0000
G1 X0.5517 Y1.7829 Z-0.0094
G1 X0.5575 Y1.7858 Z-0.0165
G1 X0.5659 Y1.7877 Z-0.0262
G1 X0.5741 Y1.7928 Z-0.0314
G1 X0.5717 Y1.8035 Z-0.0149
G1 X0.5719 Y1.8028 Z-0.0161
G1 X0.5735 Y1.7952 Z-0.0277
G1 X0.5870 Y1.7902 Z-0.0282
G1 X0.5986 Y1.7914 Z-0.0194
G1 X0.6475 Y1.7760 Z-0.0174
G1 X0.6998 Y1.7581 Z-0.0191
G0 Z#1
G0 X0.7164 Y1.7702
G1 Z-0.0000
G1 X0.7166 Y1.7888 Z-0.0238
G1 X0.6501 Y1.8490 Z-0.0250
G1 X0.6335 Y1.8618 Z-0.0282
G1 X0.6192 Y1.8600 Z-0.0112
G0 Z#1
G0 X0.6120 Y1.8589
G1 Z-0.0000
G1 X0.6179 Y1.8598 Z-0.0096
G1 X0.6263 Y1.8608 Z-0.0200
G1 X0.6330 Y1.8705 Z-0.0177
G0 Z#1
G0 X0.6345 Y1.8830
G1 Z-0.0000
G1 X0.6331 Y1.8676 Z-0.0214
G1 X0.6463 Y1.8522 Z-0.0254
G1 X0.6636 Y1.8369 Z-0.0241
G0 Z#1
G0 X0.6824 Y1.8383
G1 Z-0.0000
G1 X0.6830 Y1.8192 Z-0.0235
G1 X0.7225 Y1.7835 Z-0.0241
G2 X0.7438 Y1.7560 R0.2937 Z-0.0392
G1 X0.7679 Y1.7591 Z-0.0100
G0 Z#1
G0 X0.7746 Y1.7585
G1 Z-0.0000
G1 X0.7689 Y1.7592 Z-0.0087
G1 X0.7512 Y1.7570 Z-0.0304
G1 X0.7452 Y1.7445 Z-0.0244
G1 X0.7495 Y1.7279 Z-0.0000
G1 X0.7446 Y1.7469 Z-0.0279
G1 X0.7360 Y1.7560 Z-0.0376
G1 X0.7229 Y1.7529 Z-0.0247
G2 X0.7008 Y1.7578 R0.0495 Z-0.0192
G1 X0.6155 Y1.7866 Z-0.0175
G0 Z#1
G0 X0.5991 Y1.7779
G1 Z-0.0000
G1 X0.5865 Y1.7708 Z-0.0250
G1 X0.5922 Y1.7646 Z-0.0228
G1 X0.6451 Y1.7189 Z-0.0230
G1 X0.6705 Y1.6980 Z-0.0262
G1 X0.6818 Y1.6895 Z-0.0285
G1 X0.6912 Y1.6860 Z-0.0260
G0 Z#1
G0 X0.7933 Y1.7838
G1 Z-0.0000
G1 X0.8014 Y1.7997 Z-0.0281
G2 X0.7803 Y1.8266 R0.2517 Z-0.0259
G1 X0.7529 Y1.8646 Z-0.0244
G3 X0.7241 Y1.9026 R1.0916 Z-0.0269
G1 X0.7116 Y1.9225 Z-0.0347
G1 X0.6969 Y1.9262 Z-0.0210
G1 X0.6791 Y1.9270 Z-0.0000
G1 X0.6992 Y1.9261 Z-0.0238
G1 X0.7196 Y1.9416 Z-0.0258
G2 X0.7488 Y1.9616 R0.0618 Z-0.0258
G1 X0.7585 Y1.9635 Z-0.0293
G1 X0.7728 Y1.9598 Z-0.0308
G0 Z#1
G0 X0.7805 Y1.9761
G1 Z-0.0000
G1 X0.7791 Y1.9573 Z-0.0315
G1 X0.7857 Y1.9540 Z-0.0318
G2 X0.8173 Y1.9272 R0.1478 Z-0.0303
G1 X0.8299 Y1.9124 Z-0.0299
G1 X0.8364 Y1.9024 Z-0.0294
G2 X0.8506 Y1.8694 R0.1259 Z-0.0277
G1 X0.8523 Y1.8596 Z-0.0274
G1 X0.8527 Y1.8508 Z-0.0271
G2 X0.8506 Y1.8367 R0.0468 Z-0.0260
G2 X0.8467 Y1.8286 R0.0359 Z-0.0250
G2 X0.8396 Y1.8194 R0.0541 Z-0.0228
G1 X0.8291 Y1.8107 Z-0.0208
G1 X0.8099 Y1.8027 Z-0.0258
G1 X0.8007 Y1.7968 Z-0.0241
G2 X0.7980 Y1.7896 R0.0472 Z-0.0128
G0 Z#1
G0 X0.7365 Y1.9401
G1 Z-0.0000
G1 X0.7260 Y1.9485 Z-0.0233
G1 X0.7210 Y1.9432 Z-0.0251
G1 X0.7146 Y1.9345 Z-0.0299
G3 X0.7104 Y1.9250 R0.0310 Z-0.0364
G3 X0.7176 Y1.9119 R0.0998 Z-0.0293
G3 X0.7305 Y1.8946 R0.1566 Z-0.0259
G1 X0.7503 Y1.8682 Z-0.0245
G1 X0.7942 Y1.8083 Z-0.0274
G1 X0.8014 Y1.8020 Z-0.0306
G1 X0.8154 Y1.8040 Z-0.0233
G1 X0.8266 Y1.8091 Z-0.0208
G3 X0.8370 Y1.8169 R0.1034 Z-0.0223
G3 X0.8469 Y1.8289 R0.0533 Z-0.0251
G1 X0.8499 Y1.8350 Z-0.0259
G3 X0.8525 Y1.8456 R0.0467 Z-0.0267
G3 X0.8513 Y1.8663 R0.0715 Z-0.0278
G3 X0.8435 Y1.8890 R0.1029 Z-0.0279
G1 X0.8343 Y1.9059 Z-0.0298
G3 X0.8027 Y1.9415 R0.1920 Z-0.0308
G1 X0.7900 Y1.9513 Z-0.0318
G1 X0.7758 Y1.9587 Z-0.0312
G3 X0.7584 Y1.9635 R0.0681 Z-0.0293
G1 X0.7455 Y1.9604 Z-0.0249
G1 X0.7345 Y1.9549 Z-0.0227
G0 Z#1
G0 X0.9010 Y2.1847
G1 Z-0.0000
G1 X0.8996 Y2.1850 Z-0.0019
G1 X0.7341 Y2.1478 Z-0.0693
G1 X0.6635 Y2.1265 Z-0.1066
G1 X0.6543 Y2.1211 Z-0.1083
G1 X0.5933 Y2.0776 Z-0.1083
G1 X0.4743 Y1.9663 Z-0.1083
G3 X0.4483 Y1.9364 R0.2755 Z-0.1083
G1 X0.3792 Y1.8476 Z-0.1083
G1 X0.3736 Y1.8390 Z-0.1068
G1 X0.3650 Y1.8114 Z-0.0918
G1 X0.3588 Y1.7892 Z-0.0809
G1 X0.3432 Y1.7283 Z-0.0532
G1 X0.3293 Y1.6692 Z-0.0282
G1 X0.3241 Y1.6444 Z-0.0186
G1 X0.3175 Y1.6102 Z-0.0064
G1 X0.3162 Y1.6051 Z-0.0041
G0 Z#1
G0 X0.3139 Y1.6024
G1 Z-0.0000
G3 X0.3201 Y1.6237 R0.0562 Z-0.0113
G1 X0.3263 Y1.6556 Z-0.0226
G1 X0.3540 Y1.7718 Z-0.0726
G1 X0.3683 Y1.8231 Z-0.0975
G3 X0.3744 Y1.8436 R0.2141 Z-0.1083
G1 X0.3743 Y1.8845 Z-0.1083
G1 X0.3743 Y1.9047 Z-0.1083
G1 X0.3743 Y2.1173 Z-0.1083
G1 X0.3726 Y2.1274 Z-0.1052
G1 X0.3118 Y2.1882 Z-0.0000
G1 X0.3732 Y2.1268 Z-0.1063
G1 X0.3834 Y2.1257 Z-0.1083
G1 X0.6599 Y2.1256 Z-0.1083
G1 X0.7116 Y2.1418 Z-0.0799
G1 X0.8900 Y2.1828 Z-0.0060
G0 Z#1
G0 X1.0369 Y2.2239
G1 Z-0.0000
G1 X1.0324 Y2.2245 Z-0.0032
G1 X1.0011 Y2.2210 Z-0.0097
G1 X0.9886 Y2.2203 Z-0.0111
G1 X0.2850 Y2.2185 Z-0.0164
G1 X0.2833 Y2.2179 Z-0.0173
G1 X0.2821 Y2.2167 Z-0.0173
G1 X0.2810 Y2.2118 Z-0.0154
G1 X0.2809 Y2.2000 Z-0.0153
G1 X0.2809 Y1.8511 Z-0.0153
G1 X0.2809 Y1.8410 Z-0.0153
G1 X0.2809 Y1.6992 Z-0.0148
G3 X0.2809 Y1.6789 R14.2839 Z-0.0147
G1 X0.2810 Y1.6485 Z-0.0145
G2 X0.2809 Y1.6170 R3.7227 Z-0.0139
G1 X0.2806 Y1.5738 Z-0.0129
G1 X0.2805 Y1.5522 Z-0.0124
G2 X0.2799 Y1.5193 R1.6341 Z-0.0107
G1 X0.2794 Y1.4969 Z-0.0094
G2 X0.2784 Y1.4791 R0.1047 Z-0.0073
G2 X0.2761 Y1.4697 R0.0593 Z-0.0031
G0 Z#1
G0 X0.2743 Y1.4672
G1 Z-0.0000
G3 X0.2792 Y1.4886 R0.0433 Z-0.0089
G1 X0.2805 Y1.5422 Z-0.0121
G1 X0.2806 Y1.5636 Z-0.0127
G1 X0.2807 Y1.5844 Z-0.0132
G1 X0.2810 Y1.6353 Z-0.0143
G3 X0.2810 Y1.6557 R3.7207 Z-0.0145
G1 X0.2809 Y1.6862 Z-0.0147
G2 X0.2809 Y1.7176 R12.7444 Z-0.0149
G1 X0.2809 Y1.8345 Z-0.0152
G1 X0.2809 Y1.8552 Z-0.0153
G1 X0.2809 Y1.8653 Z-0.0153
G1 X0.2809 Y2.2078 Z-0.0153
G1 X0.2821 Y2.2179 Z-0.0174
G1 X0.2721 Y2.2279 Z-0.0000
G1 X0.2822 Y2.2178 Z-0.0175
G2 X0.3025 Y2.2191 R0.0800 Z-0.0153
G1 X0.9882 Y2.2203 Z-0.0111
G1 X1.0285 Y2.2240 Z-0.0042
G0 Z#1
G0 X1.1275 Y2.1314
G1 Z-0.0000
G1 X1.1326 Y2.1278 Z-0.0104
G1 X1.1398 Y2.1238 Z-0.0224
G1 X1.1511 Y2.1167 Z-0.0357
G2 X1.1824 Y2.1244 R0.0700 Z-0.0238
G2 X1.2054 Y2.1229 R0.1252 Z-0.0252
G1 X1.2126 Y2.1205 Z-0.0258
G0 Z#1
G0 X1.2213 Y2.1330
G1 Z-0.0000
G1 X1.2167 Y2.1181 Z-0.0261
G1 X1.2254 Y2.1097 Z-0.0282
G1 X1.2279 Y2.1044 Z-0.0289
G1 X1.2292 Y2.1003 Z-0.0291
G1 X1.2309 Y2.0908 Z-0.0281
G1 X1.2318 Y2.0772 Z-0.0271
G1 X1.2313 Y2.0699 Z-0.0272
G1 X1.2300 Y2.0655 Z-0.0269
G2 X1.2241 Y2.0562 R0.0386 Z-0.0253
G2 X1.1978 Y2.0318 R0.1223 Z-0.0311
G1 X1.1959 Y2.0294 Z-0.0319
G3 X1.1978 Y2.0232 R0.0388 Z-0.0261
G1 X1.1998 Y2.0187 Z-0.0232
G3 X1.2104 Y2.0032 R0.1293 Z-0.0215
G1 X1.2352 Y1.9645 Z-0.0247
G1 X1.2445 Y1.9586 Z-0.0187
G1 X1.2659 Y1.9510 Z-0.0000
G1 X1.2391 Y1.9607 Z-0.0233
G1 X1.2345 Y1.9566 Z-0.0164
G0 Z#1
G0 X1.2277 Y1.9498
G1 Z-0.0000
G1 X1.2368 Y1.9607 Z-0.0235
G1 X1.2324 Y1.9686 Z-0.0242
G1 X1.2133 Y1.9987 Z-0.0216
G3 X1.2002 Y2.0180 R0.8673 Z-0.0229
G1 X1.1963 Y2.0277 Z-0.0302
G0 Z#1
G0 X1.1765 Y2.0181
G1 Z-0.0000
G1 X1.1588 Y2.0271 Z-0.0343
G1 X1.1579 Y2.0227 Z-0.0322
G1 X1.1572 Y2.0180 Z-0.0305
G1 X1.1568 Y2.0129 Z-0.0293
G1 X1.1568 Y2.0051 Z-0.0285
G3 X1.1576 Y1.9810 R0.5211 Z-0.0279
G1 X1.1587 Y1.9644 Z-0.0283
G1 X1.1664 Y1.9548 Z-0.0163
G1 X1.1766 Y1.9454 Z-0.0000
G1 X1.1683 Y1.9531 Z-0.0133
G1 X1.1516 Y1.9541 Z-0.0152
G1 X1.1432 Y1.9454 Z-0.0000
G3 X1.1585 Y1.9664 R0.0442 Z-0.0282
G2 X1.1573 Y1.9866 R1.1535 Z-0.0278
G2 X1.1574 Y2.0199 R0.3065 Z-0.0311
G3 X1.1505 Y2.0716 R1.4729 Z-0.0271
G2 X1.1479 Y2.1070 R0.1684 Z-0.0321
G1 X1.1474 Y2.1174 Z-0.0342
G1 X1.1377 Y2.1253 Z-0.0188
G0 Z#1
G0 X1.1738 Y2.1087
G1 Z-0.0000
G1 X1.1657 Y2.1223 Z-0.0274
G1 X1.1559 Y2.1189 Z-0.0323
G1 X1.1486 Y2.1127 Z-0.0352
G1 X1.1480 Y2.1079 Z-0.0326
G1 X1.1477 Y2.1035 Z-0.0306
G3 X1.1483 Y2.0902 R0.1224 Z-0.0276
G3 X1.1521 Y2.0587 R2.6676 Z-0.0274
G3 X1.1543 Y2.0456 R0.0828 Z-0.0291
G1 X1.1557 Y2.0411 Z-0.0307
G0 Z#1
G0 X1.1749 Y2.0476
G1 Z-0.0000
G1 X1.1747 Y2.0331 Z-0.0250
G2 X1.1848 Y2.0324 R0.0521 Z-0.0254
G2 X1.1956 Y2.0302 R0.1155 Z-0.0325
G1 X1.2079 Y2.0396 Z-0.0269
G3 X1.2205 Y2.0520 R0.1303 Z-0.0253
G3 X1.2288 Y2.0631 R0.0651 Z-0.0266
G1 X1.2310 Y2.0685 Z-0.0272
G3 X1.2317 Y2.0826 R0.0563 Z-0.0277
G3 X1.2295 Y2.0991 R0.1416 Z-0.0290
G1 X1.2274 Y2.1057 Z-0.0289
G0 Z#1
G0 X1.2093 Y2.1047
G1 Z-0.0000
G1 X1.2181 Y2.1172 Z-0.0263
G1 X1.2096 Y2.1217 Z-0.0256
G1 X1.1913 Y2.1243 Z-0.0236
G1 X1.1781 Y2.1242 Z-0.0243
G1 X1.1714 Y2.1235 Z-0.0257
G0 Z#1
G0 X1.1926 Y2.2165
G1 Z-0.0000
G1 X1.1809 Y2.2228 Z-0.0133
G1 X1.0525 Y2.2045 Z-0.0155
G1 X0.9712 Y2.1839 Z-0.0144
G1 X0.8664 Y2.1445 Z-0.0110
G1 X0.8175 Y2.1227 Z-0.0141
G1 X0.7709 Y2.0966 Z-0.0108
G1 X0.6798 Y2.0394 Z-0.0133
G1 X0.5967 Y1.9697 Z-0.0109
G1 X0.5490 Y1.9249 Z-0.0147
G1 X0.5202 Y1.8927 Z-0.0119
G1 X0.4524 Y1.8084 Z-0.0136
G1 X0.3960 Y1.7160 Z-0.0118
G1 X0.3802 Y1.6875 Z-0.0136
G1 X0.3756 Y1.6779 Z-0.0138
G1 X0.3503 Y1.6197 Z-0.0110
G1 X0.3238 Y1.5498 Z-0.0142
G1 X0.3206 Y1.5397 Z-0.0139
G1 X0.3148 Y1.5193 Z-0.0123
G1 X0.3006 Y1.4620 Z-0.0112
G1 X0.2893 Y1.4094 Z-0.0131
G1 X0.2863 Y1.3880 Z-0.0131
G1 X0.2834 Y1.3562 Z-0.0124
G3 X0.2811 Y1.3238 R1.1519 Z-0.0128
G1 X0.2791 Y1.2916 Z-0.0137
G3 X0.2778 Y1.2588 R0.9006 Z-0.0160
G1 X0.2779 Y1.2481 Z-0.0163
G1 X0.2823 Y1.1627 Z-0.0127
G3 X0.2852 Y1.1299 R0.5492 Z-0.0136
G1 X0.2876 Y1.1087 Z-0.0149
G1 X0.2893 Y1.0981 Z-0.0147
G1 X0.2992 Y1.0456 Z-0.0109
G3 X0.3067 Y1.0141 R0.4696 Z-0.0112
G1 X0.3199 Y0.9633 Z-0.0137
G1 X0.3230 Y0.9533 Z-0.0134
G1 X0.3299 Y0.9335 Z-0.0116
G3 X0.3414 Y0.9040 R0.4863 Z-0.0113
G1 X0.3767 Y0.8197 Z-0.0137
G1 X0.4291 Y0.7270 Z-0.0141
G3 X0.4473 Y0.6999 R0.5487 Z-0.0129
G1 X0.4849 Y0.6485 Z-0.0149
G1 X0.5049 Y0.6238 Z-0.0131
G1 X0.5552 Y0.5684 Z-0.0150
G1 X0.5853 Y0.5388 Z-0.0130
G1 X0.6336 Y0.4965 Z-0.0149
G1 X0.6753 Y0.4640 Z-0.0131
G1 X0.7105 Y0.4391 Z-0.0150
G1 X0.7737 Y0.4005 Z-0.0134
G1 X0.8789 Y0.3491 Z-0.0139
G1 X0.9903 Y0.3106 Z-0.0141
G1 X1.1056 Y0.2862 Z-0.0130
G1 X1.1671 Y0.2798 Z-0.0118
G1 X1.2414 Y0.2764 Z-0.0130
G1 X1.3386 Y0.2790 Z-0.0132
G1 X1.4419 Y0.2937 Z-0.0140
G1 X1.5272 Y0.3154 Z-0.0125
G1 X1.5587 Y0.3249 Z-0.0137
G1 X1.6714 Y0.3706 Z-0.0138
G1 X1.7714 Y0.4258 Z-0.0149
G3 X1.7977 Y0.4434 R0.4971 Z-0.0134
G1 X1.8797 Y0.5047 Z-0.0144
G1 X1.9688 Y0.5906 Z-0.0136
G1 X2.0222 Y0.6541 Z-0.0156
G1 X2.0466 Y0.6870 Z-0.0135
G1 X2.0756 Y0.7304 Z-0.0153
G1 X2.1115 Y0.7925 Z-0.0131
G1 X2.1262 Y0.8206 Z-0.0144
G1 X2.1631 Y0.9051 Z-0.0139
G3 X2.1734 Y0.9351 R0.3033 Z-0.0139
G1 X2.1943 Y1.0037 Z-0.0150
G1 X2.1995 Y1.0235 Z-0.0138
G3 X2.2059 Y1.0545 R0.4984 Z-0.0138
G1 X2.2133 Y1.0949 Z-0.0153
G1 X2.2204 Y1.1456 Z-0.0134
G3 X2.2235 Y1.1773 R0.4985 Z-0.0145
G1 X2.2239 Y1.1876 Z-0.0147
G1 X2.2261 Y1.2597 Z-0.0144
G1 X2.2263 Y1.2700 Z-0.0142
G3 X2.2244 Y1.3018 R0.4944 Z-0.0139
G1 X2.2203 Y1.3532 Z-0.0154
G1 X2.2153 Y1.3941 Z-0.0135
G3 X2.2099 Y1.4256 R0.4972 Z-0.0143
G1 X2.2080 Y1.4358 Z-0.0149
G1 X2.2058 Y1.4459 Z-0.0152
G1 X2.1889 Y1.5162 Z-0.0139
G3 X2.1793 Y1.5466 R0.2897 Z-0.0141
G1 X2.1547 Y1.6146 Z-0.0148
G1 X2.1468 Y1.6338 Z-0.0135
G1 X2.1198 Y1.6908 Z-0.0154
G1 X2.0896 Y1.7452 Z-0.0127
G1 X2.0562 Y1.7987 Z-0.0157
G1 X2.0194 Y1.8488 Z-0.0131
G1 X1.9792 Y1.8977 Z-0.0160
G1 X1.9360 Y1.9427 Z-0.0129
G1 X1.8897 Y1.9860 Z-0.0153
G1 X1.8411 Y2.0251 Z-0.0119
G1 X1.7822 Y2.0667 Z-0.0143
G1 X1.7390 Y2.0933 Z-0.0121
G1 X1.6926 Y2.1186 Z-0.0147
G1 X1.6260 Y2.1490 Z-0.0127
G1 X1.5861 Y2.1648 Z-0.0146
G1 X1.5059 Y2.1904 Z-0.0132
G1 X1.3831 Y2.2159 Z-0.0137
G1 X1.3465 Y2.2202 Z-0.0134
G1 X1.2330 Y2.2244 Z-0.0121
G3 X1.1809 Y2.2228 R0.6345 Z-0.0133
G0 Z#1
G0 X1.0634 Y2.0871
G1 Z-0.0000
G1 X1.0607 Y2.0675 Z-0.0266
G1 X1.0805 Y2.0688 Z-0.0000
G1 X1.0678 Y2.0680 Z-0.0171
G1 X1.0595 Y2.0566 Z-0.0169
G1 X1.0586 Y2.0487 Z-0.0092
G1 X1.0584 Y2.0483 Z-0.0086
G0 Z#1
G0 X1.0541 Y2.0456
G1 Z-0.0000
G1 X1.0593 Y2.0541 Z-0.0146
G1 X1.0602 Y2.0639 Z-0.0237
G1 X1.0573 Y2.0715 Z-0.0261
G3 X1.0468 Y2.0825 R0.0877 Z-0.0259
G1 X1.0419 Y2.0864 Z-0.0268
G1 X1.0363 Y2.0894 Z-0.0273
G1 X1.0238 Y2.0917 Z-0.0268
G1 X1.0112 Y2.0908 Z-0.0277
G1 X1.0049 Y2.0893 Z-0.0288
G1 X0.9981 Y2.0861 Z-0.0298
G1 X0.9915 Y2.0810 Z-0.0299
G1 X0.9861 Y2.0745 Z-0.0291
G3 X0.9791 Y2.0601 R0.0772 Z-0.0274
G3 X0.9755 Y2.0448 R0.0694 Z-0.0274
G3 X0.9768 Y2.0144 R0.1198 Z-0.0269
G3 X0.9850 Y1.9790 R0.2209 Z-0.0267
G3 X0.9958 Y1.9561 R0.0993 Z-0.0260
G1 X1.0023 Y1.9474 Z-0.0258
G3 X1.0141 Y1.9365 R0.0684 Z-0.0254
G1 X1.0265 Y1.9297 Z-0.0255
G1 X1.0332 Y1.9274 Z-0.0257
G1 X1.0472 Y1.9256 Z-0.0260
G1 X1.0611 Y1.9274 Z-0.0265
G1 X1.0678 Y1.9298 Z-0.0266
G1 X1.0740 Y1.9333 Z-0.0266
G1 X1.0796 Y1.9377 Z-0.0265
G1 X1.0846 Y1.9432 Z-0.0264
G3 X1.0918 Y1.9568 R0.0481 Z-0.0261
G1 X1.0937 Y1.9641 Z-0.0259
G1 X1.0945 Y1.9717 Z-0.0257
G3 X1.0932 Y1.9854 R0.0596 Z-0.0254
G3 X1.0903 Y1.9954 R0.0596 Z-0.0271
G1 X1.0869 Y2.0026 Z-0.0294
G1 X1.0847 Y2.0056 Z-0.0305
G0 Z#1
G0 X1.0697 Y1.9934
G1 Z-0.0000
G1 X1.0666 Y2.0060 Z-0.0224
G3 X1.0549 Y2.0025 R0.0735 Z-0.0232
G1 X1.0431 Y1.9983 Z-0.0249
G1 X1.0375 Y1.9880 Z-0.0114
G0 Z#1
G0 X1.0317 Y1.9847
G1 Z-0.0000
G1 X1.0403 Y1.9940 Z-0.0200
G1 X1.0367 Y2.0005 Z-0.0182
G1 X1.0307 Y2.0041 Z-0.0095
G0 Z#1
G0 X1.0283 Y2.0091
G1 Z-0.0000
G1 X1.0404 Y1.9985 Z-0.0233
G2 X1.0803 Y2.0064 R0.1238 Z-0.0273
G1 X1.0898 Y2.0151 Z-0.0165
G1 X1.0917 Y2.0188 Z-0.0104
G1 X1.0865 Y2.0081 Z-0.0270
G1 X1.0884 Y1.9998 Z-0.0283
G2 X1.0945 Y1.9743 R0.0649 Z-0.0255
G1 X1.0941 Y1.9673 Z-0.0256
G1 X1.0929 Y1.9604 Z-0.0258
G1 X1.0906 Y1.9538 Z-0.0260
G2 X1.0837 Y1.9421 R0.0466 Z-0.0264
G1 X1.0793 Y1.9374 Z-0.0265
G1 X1.0742 Y1.9334 Z-0.0266
G1 X1.0687 Y1.9302 Z-0.0266
G1 X1.0627 Y1.9279 Z-0.0265
G2 X1.0458 Y1.9256 R0.0549 Z-0.0259
G2 X1.0277 Y1.9293 R0.0528 Z-0.0255
G2 X1.0103 Y1.9395 R0.0630 Z-0.0253
G1 X1.0029 Y1.9468 Z-0.0257
G1 X0.9966 Y1.9549 Z-0.0260
G2 X0.9866 Y1.9745 R0.0917 Z-0.0265
G2 X0.9762 Y2.0193 R0.2064 Z-0.0269
G2 X0.9756 Y2.0458 R0.1033 Z-0.0273
G2 X0.9821 Y2.0672 R0.0696 Z-0.0279
G1 X0.9889 Y2.0783 Z-0.0295
G1 X0.9955 Y2.0844 Z-0.0299
G1 X1.0026 Y2.0884 Z-0.0291
G2 X1.0185 Y2.0917 R0.0502 Z-0.0269
G2 X1.0351 Y2.0897 R0.0568 Z-0.0272
G1 X1.0418 Y2.0865 Z-0.0268
G1 X1.0479 Y2.0816 Z-0.0257
G0 Z#1
G0 X1.3891 Y1.8556
G1 X1.3957 Y1.8432 Z-0.0170
G1 X1.4345 Y1.8321 Z-0.0149
G1 X1.4726 Y1.8189 Z-0.0167
G1 X1.5600 Y1.7765 Z-0.0169
G1 X1.6219 Y1.7339 Z-0.0167
G1 X1.6392 Y1.7204 Z-0.0181
G1 X1.6705 Y1.6927 Z-0.0164
G1 X1.7083 Y1.6537 Z-0.0176
G2 X1.7281 Y1.6305 R0.1869 Z-0.0174
G1 X1.7471 Y1.6055 Z-0.0179
G2 X1.7654 Y1.5791 R0.2770 Z-0.0173
G1 X1.7772 Y1.5597 Z-0.0182
G1 X1.7982 Y1.5212 Z-0.0172
G1 X1.8030 Y1.5111 Z-0.0175
G1 X1.8153 Y1.4832 Z-0.0166
G1 X1.8263 Y1.4548 Z-0.0164
G2 X1.8357 Y1.4259 R0.2825 Z-0.0162
G1 X1.8416 Y1.4057 Z-0.0164
G1 X1.8466 Y1.3848 Z-0.0166
G1 X1.8514 Y1.3616 Z-0.0167
G1 X1.8550 Y1.3390 Z-0.0167
G1 X1.8577 Y1.3152 Z-0.0165
G2 X1.8603 Y1.2823 R0.2756 Z-0.0156
G1 X1.8608 Y1.2606 Z-0.0160
G1 X1.8609 Y1.2398 Z-0.0157
G2 X1.8602 Y1.2188 R0.2143 Z-0.0158
G1 X1.8596 Y1.2084 Z-0.0163
G1 X1.8578 Y1.1869 Z-0.0167
G2 X1.8554 Y1.1635 R0.9814 Z-0.0166
G1 X1.8516 Y1.1414 Z-0.0173
G1 X1.8472 Y1.1188 Z-0.0172
G2 X1.8384 Y1.0843 R0.3534 Z-0.0172
G1 X1.8350 Y1.0723 Z-0.0173
G1 X1.8285 Y1.0516 Z-0.0168
G2 X1.8214 Y1.0325 R0.2865 Z-0.0167
G1 X1.8139 Y1.0136 Z-0.0172
G1 X1.8022 Y0.9865 Z-0.0162
G1 X1.7881 Y0.9594 Z-0.0169
G1 X1.7736 Y0.9335 Z-0.0159
G1 X1.7567 Y0.9077 Z-0.0169
G1 X1.7395 Y0.8834 Z-0.0161
G1 X1.7199 Y0.8596 Z-0.0174
G1 X1.6932 Y0.8296 Z-0.0167
G1 X1.6785 Y0.8151 Z-0.0178
G1 X1.6331 Y0.7746 Z-0.0175
G1 X1.5839 Y0.7386 Z-0.0172
G1 X1.5313 Y0.7077 Z-0.0169
G2 X1.5044 Y0.6944 R0.1781 Z-0.0163
G1 X1.4757 Y0.6822 Z-0.0169
G1 X1.4475 Y0.6716 Z-0.0158
G1 X1.4177 Y0.6626 Z-0.0167
G1 X1.3882 Y0.6549 Z-0.0157
G1 X1.2951 Y0.6422 Z-0.0177
G1 X1.2325 Y0.6407 Z-0.0175
G1 X1.1699 Y0.6452 Z-0.0167
G1 X1.1086 Y0.6562 Z-0.0165
G1 X1.0488 Y0.6736 Z-0.0168
G1 X0.9969 Y0.6949 Z-0.0177
G2 X0.9666 Y0.7099 R0.2017 Z-0.0171
G1 X0.9114 Y0.7430 Z-0.0161
G1 X0.8482 Y0.7921 Z-0.0163
G1 X0.8052 Y0.8339 Z-0.0165
G1 X0.7666 Y0.8797 Z-0.0174
G2 X0.7472 Y0.9060 R0.2451 Z-0.0169
G1 X0.7345 Y0.9257 Z-0.0179
G1 X0.7112 Y0.9651 Z-0.0168
G1 X0.7060 Y0.9756 Z-0.0175
G1 X0.6801 Y1.0346 Z-0.0162
G1 X0.6764 Y1.0448 Z-0.0169
G1 X0.6701 Y1.0641 Z-0.0171
G1 X0.6581 Y1.1055 Z-0.0154
G1 X0.6557 Y1.1161 Z-0.0162
G1 X0.6519 Y1.1362 Z-0.0166
G1 X0.6485 Y1.1576 Z-0.0161
G1 X0.6450 Y1.1901 Z-0.0178
G1 X0.6433 Y1.2105 Z-0.0179
G2 X0.6426 Y1.2322 R0.3857 Z-0.0175
G1 X0.6420 Y1.2648 Z-0.0176
G2 X0.6432 Y1.2960 R0.2102 Z-0.0164
G1 X0.6471 Y1.3391 Z-0.0159
G1 X0.6508 Y1.3592 Z-0.0168
G1 X0.6624 Y1.4120 Z-0.0166
G1 X0.6682 Y1.4314 Z-0.0171
G1 X0.6862 Y1.4814 Z-0.0175
G2 X0.6987 Y1.5093 R0.1825 Z-0.0174
G1 X0.7182 Y1.5472 Z-0.0181
G2 X0.7336 Y1.5738 R0.2569 Z-0.0174
G1 X0.7456 Y1.5914 Z-0.0183
G1 X0.7765 Y1.6336 Z-0.0171
G1 X0.8357 Y1.6959 Z-0.0151
G1 X0.8520 Y1.7106 Z-0.0168
G1 X0.9020 Y1.7497 Z-0.0148
G1 X0.9382 Y1.7736 Z-0.0174
G1 X0.9731 Y1.7940 Z-0.0168
G1 X1.0289 Y1.8187 Z-0.0177
G1 X1.0871 Y1.8384 Z-0.0171
G1 X1.1382 Y1.8503 Z-0.0171
G1 X1.1914 Y1.8575 Z-0.0157
G1 X1.2975 Y1.8577 Z-0.0165
G2 X1.3482 Y1.8531 R0.4529 Z-0.0172
G1 X1.3736 Y1.8486 Z-0.0172
G0 Z#1
G0 X1.4510 Y1.9137
G1 Z-0.0000
G1 X1.4697 Y1.9217 Z-0.0293
G1 X1.4765 Y1.9449 Z-0.0331
G1 X1.4752 Y1.9733 Z-0.0215
G2 X1.4822 Y2.0086 R0.7784 Z-0.0216
G2 X1.4940 Y2.0603 R3.0837 Z-0.0251
G1 X1.4983 Y2.0791 Z-0.0269
G1 X1.4982 Y2.0929 Z-0.0229
G1 X1.4928 Y2.1021 Z-0.0105
G1 X1.4972 Y2.0945 Z-0.0208
G0 Z#1
G0 X1.5070 Y2.1041
G1 Z-0.0000
G1 X1.5112 Y2.0947 Z-0.0129
G1 X1.5203 Y2.0995 Z-0.0000
G1 X1.5067 Y2.0924 Z-0.0193
G1 X1.4993 Y2.0836 Z-0.0274
G1 X1.4849 Y2.0207 Z-0.0222
G3 X1.4773 Y1.9852 R1.2390 Z-0.0210
G1 X1.4738 Y1.9647 Z-0.0220
G3 X1.4735 Y1.9589 R0.0432 Z-0.0234
G0 Z#1
G0 X1.4882 Y1.9608
G1 Z-0.0000
G1 X1.4990 Y1.9557 Z-0.0202
G3 X1.5092 Y1.9725 R0.4076 Z-0.0192
G1 X1.5389 Y2.0236 Z-0.0207
G1 X1.5511 Y2.0388 Z-0.0263
G1 X1.5603 Y2.0526 Z-0.0282
G1 X1.5542 Y2.0670 Z-0.0065
G0 Z#1
G0 X1.5540 Y2.0708
G1 Z-0.0000
G1 X1.5555 Y2.0641 Z-0.0111
G2 X1.5613 Y2.0496 R0.1433 Z-0.0325
G1 X1.5684 Y2.0477 Z-0.0302
G1 X1.5790 Y2.0528 Z-0.0131
G1 X1.5676 Y2.0474 Z-0.0313
G1 X1.5664 Y2.0359 Z-0.0290
G1 X1.5674 Y2.0177 Z-0.0204
G1 X1.5523 Y1.9445 Z-0.0195
G0 Z#1
G0 X1.5658 Y1.9339
G1 Z-0.0000
G1 X1.5838 Y1.9394 Z-0.0217
G1 X1.6347 Y2.0246 Z-0.0273
G1 X1.6390 Y2.0347 Z-0.0250
G1 X1.6356 Y2.0434 Z-0.0117
G1 X1.6393 Y2.0340 Z-0.0260
G1 X1.6523 Y2.0376 Z-0.0136
G0 Z#1
G0 X1.6625 Y2.0390
G1 Z-0.0000
G1 X1.6479 Y2.0360 Z-0.0186
G1 X1.6320 Y2.0202 Z-0.0271
G1 X1.6051 Y1.9742 Z-0.0231
G1 X1.5763 Y1.9274 Z-0.0215
G1 X1.5608 Y1.9145 Z-0.0325
G1 X1.5530 Y1.9034 Z-0.0338
G1 X1.5538 Y1.8947 Z-0.0244
G1 X1.5558 Y1.8892 Z-0.0151
G1 X1.5548 Y1.8923 Z-0.0205
G1 X1.5517 Y1.8999 Z-0.0324
G1 X1.5368 Y1.8915 Z-0.0088
G0 Z#1
G0 X1.5317 Y1.8917
G1 Z-0.0000
G1 X1.5489 Y1.8981 Z-0.0279
G1 X1.5547 Y1.9162 Z-0.0329
G1 X1.5517 Y1.9410 Z-0.0196
G2 X1.5617 Y1.9900 R2.2708 Z-0.0194
G1 X1.5658 Y2.0100 Z-0.0201
G0 Z#1
G0 X1.5525 Y2.0230
G1 Z-0.0000
G1 X1.5358 Y2.0183 Z-0.0205
G1 X1.5101 Y1.9740 Z-0.0192
G2 X1.4889 Y1.9451 R0.0710 Z-0.0269
G1 X1.4764 Y1.9337 Z-0.0367
G1 X1.4735 Y1.9258 Z-0.0343
G3 X1.4778 Y1.9099 R0.0547 Z-0.0131
G1 X1.4780 Y1.9091 Z-0.0117
G1 X1.4745 Y1.9188 Z-0.0266
G1 X1.4622 Y1.9173 Z-0.0178
G0 Z#1
G0 X1.6059 Y1.8528
G1 Z-0.0000
G1 X1.6138 Y1.8521 Z-0.0117
G1 X1.6268 Y1.8534 Z-0.0281
G1 X1.6338 Y1.8611 Z-0.0292
G1 X1.6503 Y1.8859 Z-0.0245
G1 X1.6715 Y1.9165 Z-0.0220
G1 X1.6917 Y1.9456 Z-0.0219
G1 X1.7077 Y1.9649 Z-0.0277
G1 X1.7165 Y1.9900 Z-0.0202
G1 X1.7121 Y2.0068 Z-0.0000
G1 X1.7203 Y1.9749 Z-0.0380
G1 X1.7267 Y1.9759 Z-0.0299
G1 X1.7369 Y1.9780 Z-0.0139
G0 Z#1
G0 X1.7448 Y1.9767
G1 Z-0.0000
G1 X1.7200 Y1.9716 Z-0.0391
G1 X1.7254 Y1.9583 Z-0.0242
G1 X1.7255 Y1.9464 Z-0.0187
G2 X1.7180 Y1.9106 R0.6773 Z-0.0166
G1 X1.7035 Y1.8513 Z-0.0187
G0 Z#1
G0 X1.7174 Y1.8321
G1 Z-0.0000
G1 X1.7344 Y1.8330 Z-0.0226
G1 X1.7723 Y1.8843 Z-0.0228
G2 X1.7972 Y1.9192 R1.6358 Z-0.0282
G1 X1.7988 Y1.9283 Z-0.0233
G0 Z#1
G0 X1.7940 Y1.9454
G1 Z-0.0000
G1 X1.7946 Y1.9428 Z-0.0043
G1 X1.7963 Y1.9386 Z-0.0106
G1 X1.7983 Y1.9303 Z-0.0208
G1 X1.8077 Y1.9239 Z-0.0203
G0 Z#1
G0 X1.8212 Y1.9228
G1 Z-0.0000
G1 X1.8139 Y1.9248 Z-0.0126
G1 X1.8046 Y1.9236 Z-0.0240
G1 X1.7942 Y1.9150 Z-0.0269
G2 X1.7736 Y1.8860 R1.5755 Z-0.0229
G1 X1.7384 Y1.8384 Z-0.0225
G2 X1.7049 Y1.8043 R0.0999 Z-0.0387
G3 X1.7107 Y1.7812 R0.4709 Z-0.0101
G1 X1.7124 Y1.7753 Z-0.0024
G0 Z#1
G0 X1.7123 Y1.7737
G1 Z-0.0000
G1 X1.7115 Y1.7785 Z-0.0066
G1 X1.7067 Y1.7967 Z-0.0296
G1 X1.7030 Y1.8059 Z-0.0392
G1 X1.6852 Y1.8016 Z-0.0123
G0 Z#1
G0 X1.6784 Y1.8037
G1 Z-0.0000
G1 X1.6998 Y1.8049 Z-0.0345
G2 X1.7006 Y1.8397 R0.2780 Z-0.0193
G1 X1.7204 Y1.9212 Z-0.0167
G1 X1.7246 Y1.9413 Z-0.0178
G1 X1.7255 Y1.9469 Z-0.0188
G0 Z#1
G0 X1.7139 Y1.9498
G1 Z-0.0000
G1 X1.7119 Y1.9678 Z-0.0314
G1 X1.7004 Y1.9579 Z-0.0228
G3 X1.6900 Y1.9432 R0.1866 Z-0.0218
G2 X1.6678 Y1.9111 R2.8782 Z-0.0223
G3 X1.6448 Y1.8777 R5.4775 Z-0.0259
G1 X1.6301 Y1.8552 Z-0.0306
G3 X1.6357 Y1.8262 R0.1674 Z-0.0000
G1 X1.6328 Y1.8381 Z-0.0134
G1 X1.6284 Y1.8536 Z-0.0300
G1 X1.6111 Y1.8518 Z-0.0083
G0 Z#1
G0 X1.8790 Y1.7341
G1 Z-0.0000
G1 X1.8820 Y1.7292 Z-0.0032
G1 X1.8885 Y1.7212 Z-0.0055
G1 X1.9064 Y1.6964 Z-0.0082
G1 X1.9165 Y1.6808 Z-0.0098
G0 Z#1
G0 X1.9265 Y1.6763
G1 Z-0.0000
G1 X1.9270 Y1.6636 Z-0.0106
G1 X1.9493 Y1.6249 Z-0.0118
G1 X1.9779 Y1.5648 Z-0.0136
G1 X1.9862 Y1.5449 Z-0.0138
G1 X2.0014 Y1.5031 Z-0.0139
G1 X2.0114 Y1.4726 Z-0.0121
G1 X2.0197 Y1.4410 Z-0.0118
G1 X2.0275 Y1.4083 Z-0.0101
G1 X2.0321 Y1.3865 Z-0.0083
G0 Z#1
G0 X2.0409 Y1.3397
G1 Z-0.0032
G1 X2.0332 Y1.3810 Z-0.0079
G1 X2.0291 Y1.4012 Z-0.0096
G1 X2.0222 Y1.4317 Z-0.0117
G1 X2.0142 Y1.4620 Z-0.0120
G1 X2.0050 Y1.4933 Z-0.0139
G1 X1.9866 Y1.5440 Z-0.0138
G1 X1.9782 Y1.5642 Z-0.0136
G1 X1.9513 Y1.6211 Z-0.0122
G1 X1.9126 Y1.6870 Z-0.0093
G1 X1.8921 Y1.7166 Z-0.0064
G1 X1.8814 Y1.7299 Z-0.0029
G0 Z#1
G0 X2.1839 Y1.6045
G1 Z-0.0000
G3 X2.1814 Y1.6229 R0.0422 Z-0.0093
G1 X2.1590 Y1.7270 Z-0.0496
G1 X2.1531 Y1.7508 Z-0.0602
G1 X2.1331 Y1.8226 Z-0.0952
G1 X2.1242 Y1.8489 Z-0.1083
G1 X2.0790 Y1.9090 Z-0.1083
G1 X2.0111 Y1.9856 Z-0.1083
G1 X1.9364 Y2.0558 Z-0.1083
G1 X1.8557 Y2.1188 Z-0.1083
G1 X1.8309 Y2.1302 Z-0.1001
G1 X1.7589 Y2.1505 Z-0.0645
G0 Z#1
G0 X1.6040 Y2.1852
G1 Z-0.0013
G1 X1.7500 Y2.1530 Z-0.0601
G1 X1.8427 Y2.1269 Z-0.1059
G1 X1.8529 Y2.1256 Z-0.1083
G1 X2.1171 Y2.1257 Z-0.1083
G1 X2.1273 Y2.1273 Z-0.1055
G1 X2.1882 Y2.1882 Z-0.0000
G1 X2.1257 Y2.1171 Z-0.1083
G1 X2.1257 Y1.9040 Z-0.1083
G1 X2.1257 Y1.8837 Z-0.1083
G1 X2.1256 Y1.8530 Z-0.1083
G3 X2.1303 Y1.8325 R0.0630 Z-0.1001
G1 X2.1562 Y1.7394 Z-0.0546
G1 X2.1771 Y1.6449 Z-0.0172
G1 X2.1834 Y1.6133 Z-0.0056
G0 Z#1
G0 X2.2201 Y1.4888
G1 Z-0.0024
G3 X2.2201 Y1.5086 R0.0918 Z-0.0095
G1 X2.2198 Y1.5266 Z-0.0113
G1 X2.2194 Y1.5501 Z-0.0125
G2 X2.2192 Y1.5828 R1.8109 Z-0.0136
G1 X2.2192 Y1.5934 Z-0.0138
G1 X2.2189 Y1.6358 Z-0.0143
G2 X2.2189 Y1.6669 R5.4882 Z-0.0145
G1 X2.2189 Y1.8420 Z-0.0149
G1 X2.2189 Y1.8523 Z-0.0149
G1 X2.2189 Y1.8728 Z-0.0149
G1 X2.2191 Y2.2000 Z-0.0153
G1 X2.2190 Y2.2118 Z-0.0154
G1 X2.2188 Y2.2134 Z-0.0158
G1 X2.2179 Y2.2167 Z-0.0173
G1 X2.2167 Y2.2179 Z-0.0173
G1 X2.2118 Y2.2190 Z-0.0154
G1 X1.5158 Y2.2203 Z-0.0111
G1 X1.4720 Y2.2245 Z-0.0032
G0 Z#1
G0 X1.4658 Y2.2263
G1 Z-0.0000
G1 X1.4758 Y2.2240 Z-0.0042
G1 X1.5059 Y2.2208 Z-0.0101
G1 X2.2078 Y2.2191 Z-0.0153
G1 X2.2179 Y2.2179 Z-0.0174
G1 X2.2279 Y2.2279 Z-0.0000
G1 X2.2178 Y2.2179 Z-0.0174
G1 X2.2191 Y2.2078 Z-0.0153
G1 X2.2189 Y1.8651 Z-0.0149
G1 X2.2189 Y1.8550 Z-0.0149
G0 Z#1
G0 X2.2275 Y1.8449
G1 Z-0.0000
G1 X2.2189 Y1.8347 Z-0.0149
G1 X2.2189 Y1.6499 Z-0.0144
G3 X2.2190 Y1.6293 R5.4094 Z-0.0142
G1 X2.2191 Y1.5985 Z-0.0139
G1 X2.2192 Y1.5776 Z-0.0135
G1 X2.2192 Y1.5669 Z-0.0133
G3 X2.2194 Y1.5455 R1.2994 Z-0.0123
G1 X2.2198 Y1.5241 Z-0.0112
G1 X2.2202 Y1.5015 Z-0.0080
G0 Z#1
G0 X2.0976 Y1.2035
G1 Z-0.0192
G1 X2.1087 Y1.1924 Z-0.0000
G1 X2.0977 Y1.2034 Z-0.0191
G1 X1.9874 Y1.2037 Z-0.0192
G1 X1.9763 Y1.1926 Z-0.0000
G1 X1.9820 Y1.1983 Z-0.0099
G1 X1.9819 Y1.2097 Z-0.0098
G1 X1.9763 Y1.2154 Z-0.0000
G1 X1.9872 Y1.2044 Z-0.0190
G1 X2.0976 Y1.2036 Z-0.0192
G1 X2.1087 Y1.2147 Z-0.0000
G1 X2.1031 Y1.2091 Z-0.0097
G1 X2.1032 Y1.1980 Z-0.0096
G0 Z#1
G0 X2.1001 Y1.1417
G1 Z-0.0000
G1 X2.0965 Y1.1494 Z-0.0127
G1 X2.0877 Y1.1545 Z-0.0198
G1 X2.0635 Y1.1561 Z-0.0166
G2 X2.0296 Y1.1590 R3.4163 Z-0.0161
G1 X1.9878 Y1.1627 Z-0.0199
G1 X1.9780 Y1.1579 Z-0.0101
G0 Z#1
G0 X1.9719 Y1.1540
G1 Z-0.0000
G1 X1.9757 Y1.1560 Z-0.0062
G1 X1.9852 Y1.1634 Z-0.0196
G1 X1.9838 Y1.1669 Z-0.0144
G1 X1.9833 Y1.1687 Z-0.0114
G0 Z#1
G0 X1.9845 Y1.1752
G1 Z-0.0000
G1 X1.9846 Y1.1648 Z-0.0176
G1 X1.9935 Y1.1621 Z-0.0195
G1 X2.0224 Y1.1597 Z-0.0165
G0 Z#1
G0 X2.0315 Y1.1682
G1 Z-0.0000
G1 X2.0388 Y1.1583 Z-0.0158
G2 X2.0725 Y1.1553 R14.9259 Z-0.0175
G1 X2.0860 Y1.1545 Z-0.0195
G1 X2.1005 Y1.1611 Z-0.0112
G1 X2.1090 Y1.1689 Z-0.0000
G1 X2.0955 Y1.1566 Z-0.0177
G1 X2.0946 Y1.1522 Z-0.0172
G1 X2.0981 Y1.1470 Z-0.0087
G0 Z#1
G0 X2.0991 Y1.1076
G1 Z-0.0000
G1 X2.0879 Y1.1064 Z-0.0185
G1 X2.0916 Y1.1028 Z-0.0109
G1 X2.0903 Y1.1037 Z-0.0136
G1 X2.0862 Y1.1075 Z-0.0205
G1 X2.0675 Y1.1057 Z-0.0210
G1 X2.0606 Y1.1034 Z-0.0236
G1 X2.0599 Y1.1000 Z-0.0200
G2 X2.0593 Y1.0941 R0.1622 Z-0.0147
G2 X2.0553 Y1.0790 R0.0490 Z-0.0135
G2 X2.0510 Y1.0687 R0.1714 Z-0.0191
G1 X2.0494 Y1.0648 Z-0.0233
G1 X2.0565 Y1.0577 Z-0.0185
G1 X2.0637 Y1.0535 Z-0.0181
G1 X2.0731 Y1.0505 Z-0.0208
G1 X2.0768 Y1.0527 Z-0.0167
G1 X2.0790 Y1.0548 Z-0.0126
G0 Z#1
G0 X2.0846 Y1.0599
G1 Z-0.0000
G1 X2.0802 Y1.0562 Z-0.0100
G1 X2.0798 Y1.0555 Z-0.0112
G1 X2.0763 Y1.0522 Z-0.0176
G1 X2.0760 Y1.0473 Z-0.0182
G1 X2.0806 Y1.0391 Z-0.0081
G0 Z#1
G0 X2.0806 Y1.0340
G1 Z-0.0000
G1 X2.0791 Y1.0421 Z-0.0118
G1 X2.0725 Y1.0506 Z-0.0206
G2 X2.0443 Y1.0653 R0.0742 Z-0.0200
G2 X1.9958 Y1.0892 R0.1600 Z-0.0210
G1 X1.9837 Y1.0985 Z-0.0281
G1 X1.9780 Y1.0985 Z-0.0258
G1 X1.9723 Y1.0931 Z-0.0152
G0 Z#1
G0 X1.9646 Y1.0881
G1 Z-0.0000
G1 X1.9724 Y1.0932 Z-0.0154
G1 X1.9767 Y1.0973 Z-0.0234
G1 X1.9704 Y1.1086 Z-0.0128
G1 X1.9630 Y1.1166 Z-0.0000
G1 X1.9747 Y1.1039 Z-0.0202
G1 X1.9935 Y1.0995 Z-0.0253
G2 X2.0225 Y1.1057 R0.0542 Z-0.0143
G2 X2.0563 Y1.1045 R0.1629 Z-0.0211
G1 X2.0838 Y1.1074 Z-0.0205
G1 X2.0888 Y1.1088 Z-0.0179
G1 X2.0918 Y1.1123 Z-0.0115
G1 X2.0890 Y1.1090 Z-0.0175
G0 Z#1
G0 X2.0498 Y1.0940
G1 Z-0.0000
G1 X2.0570 Y1.1042 Z-0.0216
G1 X2.0461 Y1.1061 Z-0.0164
G1 X2.0248 Y1.1058 Z-0.0143
G1 X2.0091 Y1.1048 Z-0.0155
G0 Z#1
G0 X2.0081 Y1.0921
G1 Z-0.0000
G1 X2.0047 Y1.0827 Z-0.0165
G1 X2.0178 Y1.0758 Z-0.0153
G1 X2.0378 Y1.0670 Z-0.0171
G0 Z#1
G0 X2.0442 Y1.0774
G1 Z-0.0000
G1 X2.0512 Y1.0690 Z-0.0188
G1 X2.0537 Y1.0746 Z-0.0149
G1 X2.0570 Y1.0841 Z-0.0124
G0 Z#1
G0 X1.9861 Y1.0609
G1 Z-0.0000
G1 X1.9865 Y1.0490 Z-0.0173
G1 X2.0300 Y1.0248 Z-0.0159
G1 X2.0433 Y1.0119 Z-0.0244
G1 X2.0535 Y1.0064 Z-0.0239
G1 X2.0571 Y1.0050 Z-0.0222
G1 X2.0625 Y1.0054 Z-0.0147
G1 X2.0588 Y1.0049 Z-0.0205
G3 X2.0628 Y0.9967 R0.0263 Z-0.0091
G0 Z#1
(code)
#3=[#3+#4]
o103 endrepeat
#9=[#9+#4]
#3=0 (reset X)
o107 endrepeat
(CUTTING OUT!!!!)
G10 L2 P2 X0 Y0 Z0 (offsets nuked)
g64p.005
#3=0 (reset)
#9=0
g0z.5
g0x0y0
t2m6
g1z.05 f5 (safety feature if I forget toolchange)
F45 (back to normal feedrate)
 o108  repeat [#10]
  o105 repeat [#5] (cutting a few things with X offset)
G55            (a g55 offset)
g0x0y0z.1
o104 repeat [#6] (number of passes for cutout)
#7=[#7-#8]
(Code)
G0 Z#1
G0 X0.0050 Y0.0050
G1 Z#7
G1 X0.0050 Y2.5150
G1 X2.5150 Y2.5150
G1 X2.5150 Y0.0050
G1 X0.0050 Y0.0050
g0z.1
(CODE)
o104 endrepeat
#7=0
#3=[#3+#4]
o105 endrepeat
#9=[#9+#4]
#3=0 (reset X)
o108 endrepeat
g0z.5
g0y0x0
g10 L2 P2 X0 Y0 Z0
 M5 M9 M2
g54z
Last edit: 13 Sep 2013 14:32 by JZHA1985.
Time to create page: 0.215 seconds
