User M-Code outputs with a 5i25 / 7i77 not working
- DaOne
- Thank you received: 6
15 Sep 2013 01:36 - 15 Sep 2013 01:36 #38831
by DaOne
User M-Code outputs with a 5i25 / 7i77 not working was created by DaOne
I must be doing something wrong here. I got the M-Codes working as I cant verify them by a text prompt however I can not get the output part to work. Can someone tell me the what the magic is thats required? Here is what I am using. If I uncomment out the display text part it will display the text dialog box so I know the m-code itself is working just not the actual output. Do I need to define that output in hal first for this to work?
#M110
#!/bin/bash
zenity --info --text="M110 - Quill Out"
halcmd setp hm2_5i25.0.7i77.0.0.output-11 True
exit 0
Last edit: 15 Sep 2013 01:36 by DaOne.
- Thank you received: 5326
15 Sep 2013 03:20 #38834
Replied by PCW on topic User M-Code outputs with a 5i25 / 7i77 not working
Actually its sort of the opposite, you cannot have the pin connected to a
driving source in the HAL file or the setp will fail
I would just do the:
halcmd setp hm2_5i25.0.7i77.0.0.output-11 False
in a terminal to verify that it works first
- DaOne
15 Sep 2013 03:22 #38835
by DaOne
Replied by DaOne on topic User M-Code outputs with a 5i25 / 7i77 not working
Its not in the hall file but it still won't work.
15 Sep 2013 03:34 #38836
Did you try from the command line?
Is the pin true?
Is the pin true?
- DaOne
15 Sep 2013 04:38 #38838
by DaOne
Command line works fine. Mcode does not work.
15 Sep 2013 05:03 #38839
So does running the script by hand work?
- DaOne
15 Sep 2013 07:00 #38843
by DaOne
I am not sure if it does. I did however put a line in there to give me a text dialog to be sure it was actually running the macro and it displays the text. It just wont switch the output.
15 Sep 2013 07:23 #38844
I guess I was suggesting that you try running the script by hand first...
also piping the output of the halcmd to a file or log might help,
maybe this is as simple as a path problem
- DaOne
15 Sep 2013 07:30 #38845
by DaOne
By hand you are referring to from the command line correct? I am not sure how to pipe it to a file or log. I am baffled that I have the mcode confirmed working based on the text dialog and the line I am trying to run working in command line but they both refuse to work together. What if I named the pin in hal and then switched the name to true? I am guessing that wont work either since from what I read you must access the pin directly?
15 Sep 2013 08:00 #38849
I mean does running the script from the command line work?
Time to create page: 0.107 seconds
