LinuxCNC cutting corners while staright line GCode
29 Sep 2013 02:43 #39333 by Rick G
Somewhere between where you get the path-following you want
Just to be clear with the proper use of G64 Pxxx Qxxx you can set the exact path tolerance that you which to achieve.
linuxcnc will adjust the speed going into and leaving a corner to achieve that result without rounding or overshooting more than the set amount.
With better acceleration linuxcnc will be able to maintain the requested velocity further into and out of the corner.
Rick G
Time to create page: 0.133 seconds
